surlyoldbill
Following the locking issues for a few years, I stumbled on the dash switch indicator light instructions. Seeing that my driver door indicator was blinking (door not closed) even when it WAS closed, I decided to take a look at the wires. I found that the green/black stripe wire was cut, and the yellow/black stripe wire was on the way. I also found that the black wire was running through the door attachment, rubber stop. It has plenty of free play, and I'm not sure if it is SUPPOSED to run through it, I'll look at the shop manual. It's obvious that the green and yellow wires were abraided from being pinched in the mechanism somehow. The plan is to fix the wires, and tidy it up so there is no chance of wires getting caught on anything anymore. If someone knows the routing of the black wire, if it BELONGS going through the rubber stop for some reason, let me know!
