Data Card Datacard Revealed. I'll show mine, you show yours.
220629
Key words - Vehicle Datacard VIN Info Information
Autostaretx Dick suggested we should reveal our data card information because it may help others.
A VIN check that should work to access your Datacard.
https://www.datamb.com/
Requested Update
Keith said:
... and then spent about half an hour following links to other threads, which had links to other threads, and so on, trying to find out how to get my DataCard. Then I finally came back to the original thread and found post #19 where sailquik asked people to send him an email. ... Would you mind updating your first post on the thread to let people know to go to post #19 to get instructions on how to get their DataCard, so future readers won't have to hunt for the info?
:bash: Sorry. :hugs:
A convenient "get your datacard" site is: https://www.datamb.com/
The 2006 service manual is very very close to the 2005's reality, and should help with the wiring (sect 8W): http://diysprinter.co.uk/reference/2006-VA-SM.pdf
Sailquik Roger, among others, has been kind enough to get people their Data Card info. :thumbup::thumbup: Details are in post 19.
All,
Since Sikwan (our Super Moderator) updated the website server software, I no longer need an email address
to send back the Full OEM Data Card.
The new Server software handles the multi-page .pdf files with no issues at all.
Regards,
Roger (sailquik)
This link will provide some Data Card information interpretations.
Data Card Info Interpretation
https://sprinter-source.com/forums/showthread.php?t=12943
Could i make the request that folks post their datacards to help inform/instruct the rest of us about available options and mixes?
I can't see what information on the card might be considered "privileged" or necessarily secret.
If you'd rather not have your VIN or some serial numbers known (although the upper sets of digits would help folks get a sense of the rough relative sequencing range their vehicle was produced in), they can be obscured. I can do that for you if you wish.
As an example, here's my 2005's data card, with the VIN and Engine numbers trimmed of their final 5 digits:
Here's mine.
Thanks goes to Dick for the idea. :thumbup:
I stand corrected on the 2004 model year [all being CARB certified]. My 05/04/2004 (delivery date per data card) Sprinter has this label on the black plastic injector cover.
Added:
There's some information about code definitions here.
My data cards raw text copied and pasted.
Thanks goes to Sailquik Roger for supplying them to me. :thumbup:
2004 Dodge Cargo
WD2PD644545649271
VIN WD290366215649271 0 Ext. VIN: WD2PD644545649271 Production order:
Sales designation: 316 4X2 3550 Order no. 7 4 704 37154 Dealer no.: Delivery date: 05 04 2004
Original parts
Engine no.: 647981 50 898239
Transmission: 722681 05 259504
Transfer case:
Cab:
Steering: 040903020
Platform:
Front axle 1: 730415 S 780874
Front axle 2:
Rear axle 1: 741408 I 109256
Rear axle 2:
Major assembly variant
Text Part var. design.
Engine: X 009 214 451
Transmission:
Transfer case:
Front axle 1: X 006 070 032 7304150
Front axle 2:
Rear axle 1: X 004 800 193 Y 7414080
Rear axle 2:
Lamps: HELLA/HELLA
Speedometer corr.:
Heater:
Trailer coupling:
Retarder:
PTO:
Rims: LEMMERZ
Body: 3
Wipers:
Cable winch:
SA Codes
172 No code designation available (FUEL PREHEATER)
181 No code designation available
423 No code designation available
440 No code designation available
580 No code designation available
AC6 AXLE RATIO 1 = 3.727
B90 WITHOUT LOAD-DEPENDENT BRAKE VALVE
BB0 BRAKING SYSTEM WITH ABS/ASR OR ABS/ETS
BB3 No code designation available [ELECTRONIC STABILITY PROGRAM (ESP)]
C38 REAR SPRING FOR 3.88-T WEIGHT VARIANT
C42 No code designation available (STABILIZER,REAR AXLE UNDER THE FRAME)
C45 H.D. FRONT AXLE STABILIZER
C47 H.D. SHOCK ABSORBERS
D93 ELIMINATION OF PARTITION PANEL
E88 CIGAR LIGHTER
EE8 12V BATTERY 100 AH
EF5 RADIO SOUND 10 WITH CASS.PLAYER AND 2 SPEAKERS
EK1 TERMINAL STRIP FOR CONN. TO DRIVER SEAT CUSHION
ES5 No code designation available (12V POWER SOCKET, INSTRUMENT PANEL)
FG7 STORAGE BOX AT CO-DRIVER SEAT
FG8 CUP HOLDER(S), FRONT
FS4 RIGHT ADDITIONAL MIRROR
G40 No code designation available (Auto Transmission)
H16 No code designation available
H21 ALL-RND.HEAT ABSORB.GL.W.BAND FLTR ON FR.WINDOW
HH9 AIR.COND.SYS., CONTROLLED, "TEMPMATIC"
HZ9 HEATER BOOSTER, DIESEL [HZ9 = Espar D5WZ model - one electrical connector]
IL2 EXPORT (OUTSIDE GERMANY)
J11 SPEEDOMETER IN MILES
J64 MAINTENANCE INDICATION
J65 OUTSIDE TEMPERATURE INDICATOR
JA1 INDICATOR LAMP FOR WIPER FLUID LEVEL
JW0 BACKUP WARNING SYSTEM
JW6 SERVICE MONITOR "ASSYST"
KB0 MAIN TANK 100 LITER
KL1 FUEL-LEVEL SENSOR FOR AUXILIARY HEATER
KL5 FUEL FILTER WITH WATER SEPARATOR
L05 AUTOMATIC DAYTIME DRIVING LIGHT FOR CANADA
L65 COURT. LIGHTS F. TRUNK/PASS. COMP. W. DOOR CONT.
LB5 THIRD STOP LAMP
M96 FUEL PREHEATER
MC0 ENGINE OM 647 DE 27 LA 115 KW (156 HP) 3800/RPM
MF2 ENGINE REGISTERED FOR "CARB STATES"
MS1 CRUISE CONTROL
P47 MUDFLAP FRONT
P48 MUD APRON
R65 SPARE WHEEL CARRIER UNDER FRAME END
R87 No code designation available (Spare Wheel)
RA5 DROP CENTER RIMS 6 J X 16 H2 F. 225/75 R16 RF8 TIRE MANUFACTURER MICHELIN (80)
RG8 TYRES 225/75 R16 RM0 ALL-SEASON TIRE
RM9 TIRE MAKE SPECIAL REQUEST
S22 DRIVER'S SEAT ARMREST
S25 CO-DRIVER'S SEAT ARMREST
SA5 AIRBAG DRIVER SIDE
SA6 CO-DRIVER'S AIR BAG
SB1 DRIVER SEAT, COMFORT
SB2 PASSENGER SEAT, COMFORT
SS4 "SANTOS" FABRIC SEAT COVERING
T16 SLIDING TYPE LOADING DOOR ON THE RIGHT T85 ENTRANCE GRAB AT CORNER PILLAR AT LEFT REAR
T86 ENTRANCE GRAB AT CORNER PILLAR AT RIGHT REAR
U41 No code designation available
V43 No code designation available (Wood Floor)
W54 REAR WALL DOOR,DOUBLE WING 270 DEGREES
W73 REAR WALL DOOR STEP
WM0 TELMA-RETARDER CC80
X42 NOTICE PLATES AND PRINTED MATTER IN ENGLISH
X92 COMPANY LOGO (MERCEDES-BENZ) DELETED
XL8 HIGHER WEIGHT 3,88 T
XY4 No code designation available (model Year 2004)
Y11 BRACKETS USED FOR WARNING TRIANGLE
Y17 PRE-FITTINGS FOR FIRE EXTINGUISHER
Y43 HYDRAULIC JACK
Z41 APPROVAL AS TRUCK
Z75 BODYSHELL REINFORCEMENT
Z81 FASTENING EYES
Z90 UNDERBODY CONSERVATION DELETED
ZB6 PRODUCTION PARTS KIT, FREIGHTLINER
ZU8 USA COUNTRY VERSION
ZX8 DODGE EXECUTION
9147 PAINT COLOR, ARCTIC WHITE MB 9147
2006 Passenger Wagon
Datacard
Identification number: WDR90367215967963 7
VIN: WDRPD644765967963
Chassis
Sales designation: 316 KB 4X2 3550
Order number: 7 6 705 88857
Delivery date: 25 08 2006
Paint code 1: 9147 PAINT COLOR ARCTIC WHITE MB 9147
Engine no.: 647981 51 242571
Transmission: 722681 06 644648
Steering: 072062303009
Front axle 1: 730415 T 347313
Rear axle 1: 741408 X 618036
Engine
Major assembly variant: A 647 010 06 00
Part var. design.: 64798150
Text FUER DIESES FAHRZEUG KANN ALTERNARIV DER RUMOFMOTOR A647010044580 GELIEFERT
WERDEN
FOR THIS VEHICLE THE BASIC ENGINE A647010044580 CAN BE SUPPLIED ALTERNATIVE
LY
Front axle 1
Major assembly variant: X 006 800 301
Identification number: WDR90367215967963 7 VIN: WDRPD644765967963
Copyright Daimler AG , 12/20/15 11:02 AM , EPC 2.2.1.0 DW 11/2015 Delta 4 , User: uie06119 Page: 2
Part var. design.: 7304150
Text ACHTUNG ACHSE OHNE BREMSSAETTEL UND FEDERDAEMPFERBEIN.
ACHSE VL0 1,75TO MIT:
SCHEIBENBREMSE
Rear axle 1
Major assembly variant: X 004 800 436
Part var. design.: 7414080
Text ACHSE HL0 2,2TO MIT:
SCHEIBENBREMSE
VERSCHLEISSANZEIGE S/W
ACHTUNG !! ACHSE OHNE BREMSSAETTEL !!
172 FUEL PREHEATER
BB3 ELECTRONIC STABILITY PROGRAM (ESP)
C39 COMFORT REAR SPRING FOR WEIGHT VARIANT 3,880 KG
C42 STABILIZER,REAR AXLE UNDER THE FRAME
E88 CIGAR LIGHTER
EK1 TERMINAL STRIP FOR ELECTRICAL CONNECTION
ES5 12V POWER SOCKET, INSTRUMENT PANEL
F68 HEATED AND ELECTRICALLY ADJUSTABLE OUTSIDE MIRROR
FS4 LEFT AND RIGHT AUXILIARY MIRRORS NOT HEATED
FY6 CENTRAL LOCKING WITH RADIO REMOTE CONTROL NAFTA
FZ9 TWO ADDITIONAL MASTERS
G40 AUTOMATIC TRANSMISSION
H01 HEAT INSULATION CARGO AREA/PASSENGER COMPARTMENT
H04 HEAT INSULATION DRIVER CAB
H12 HOT WATER ADDITIONAL HEATER
H13 ADDITIONAL HEAT EXCHANGER, REAR
H22 HEATED REAR WINDOW
H86 TIMER FOR HEATER BOOSTER [H86 and HZ9 combination = Espar D5W S model - 2 electrical connectors]
HH9 SEMI-AUTOMATICALLY CONTROLLED TEMPMATIC A/C
IL2 EXPORT CODE
J11 SPEEDOMETER MPH AND KM/H
JK1 "SOFT LOOK" INSTRUMENT PANEL
K60 TAIL PIPE LEADING STRAIGHT TO THE REAR
LB5 CENTER HIGH-MOUNTED BRAKE LAMP
M96 FUEL PREHEATER
MS1 TEMPOMAT (CRUISE CONTROL)
P47 MUDFLAP FRONT
P48 REAR MUD FLAPS
R87 SPARE WHEEL
RM0 ALL-SEASON TIRE
SS4 SANTOS FABRIC
T11 DOOR REINFORCEMENT IN AREA OF LOCK
T16 SLIDING DOOR RIGHT
T74 GRAB HANDLE FOR ENTRANCE
U61 SEATING, PASS.COMP.,2ND BENCH SEAT, 2ND ROW
U62 SEATS PASS. COMPARTMENT 3X SEATBENCH ROW 1 NARROW
U64 PASSEN. COMP. SEATS, 3-PASSEN. BENCH SEAT, 3RD ROW
V21 DELUXE INTERIOR TRIM
V31 WINDOW PILLAR PANELING
V36 HEADLINER
V43 WOOD FLOOR
V46 PASSENGER COMPARTMENT FLOOR MATS
V50 ELECTRIC WINDOW LIFTER, 2-WAY
V64 ASHTRAY IN PASSENGER COMPARTMENT
W54 REAR-END DOORS, DOUBLE-WING, OPENING TO SIDE WALL
WM0 SPRINTER FACELIFT 2003
X42 PLATES / PRINTED MATERIALS ENGLISH
XC8 VIN VISIBLE FROM OUTSIDE
XL8 WEIGHT VARIANT 3880 KG
XY6 MODEL YEAR 6
Y43 HYDRAULIC JACK
ZX9 FREIGHTLINER EXECUTION
sailquik
Re: Data Card Revealed. I'll show mine, you show yours.
Guys (and gals),
I will be happy to help with getting you your data cards, but there is a small issue that I have found no "work around" to solve.
The Sprinter-Source server does not like attachments, so if you would like your data card, you need to send me an email that I can
send it back to.
send it back to.
...or simply agree to having it posted here as the "delivery" method?
sailquik
Dick,
That would work as well!
Gee, I'll have to poll the members who have asked for them in the past.
Guess I have about a dozen or so.
sailquik
Dick/Vic,
OK, if we go forward with this idea, where will we post the Data Cards, and how do we get around the "no attachments" issue?
Here in this thread? (although i'd have preferred "datacard" in the title instead of the two-word form...easier searching)
Member requests datacard, is told of "let us post it here" as preferred method of "delivery", provides VIN.
You create datacard and simply attach it to a post here (as i did, back up as message number 2).
They come here to fetch it (and those of us who are interested can do it, too).
Does that sound workable? You'd only need to come here for the "delivery".
Otherwise it'll be the usual email back-and-forths until you have an email address to scribble to...
(we really do appreciate your willingness to fetch a datacard, as we did (and do) when Jon Caples did/does them, too)
p.s. have you noticed this request? https://sprinter-source.com/forums/showthread.php?t=25798
VIN WD0PD144165871918
oldemettle
05 118"
I'd like a Data Card for our badged Dodge 05 118" Cargo - VIN WD2PD144155733298
Thanks, Jim
bc339
If you have a version of Adobe Acrobat Pro, it allows a document to be printed as a PDF.
I can help out with converting them to a pdf.
Here is my datacard.
Bruce
For the curious (i was), the little chunk of German in Bruce's card:
SCHEIBENBREMSE
ACHTUNG !! ACHSE OHNE BREMSSÄTTEL !!
translates to:
DISC BRAKE
WEAR S / W
Attention! AXLE WITHOUT CALIPERS!
oldemettle's has "FERDERDAEMPFERBEIN" added to the "without" list, but Google Translate isn't venturing a suggestion...
why cannot i post this in a more easily read fashion?
Do you mean like this? (using israndy's for the example):
VIN WDR90367115821254 6 Ext. VIN: WDRPD144355821254 Production order:
Sales designation: 316 KB 4X2 3000 Order no. 7 5 705 84792 Dealer no.: Delivery date: 15 06 2005
Original parts Major assembly variant Lamps: HELLA/HELLA
Engine no.: 647981 51 069121 Text Part var. design. Speedometer corr.:
Transmission: 722681 06 129383 Engine: A 647 000 00 00 Y 647XXX0 Heater:
Transfer case: Transmission: Trailer coupling:
Cab: Transfer case: Retarder:
Steering: 051591146 Front axle 1: X 006 800 112 Y 7304130 PTO:
Platform: Front axle 2: Rims: KRONPRINZ
Front axle 1: 730413 S 917835 Rear axle 1: X 004 800 193 Y 7414080 Body: 3
Front axle 2: Rear axle 2: Wipers:
Rear axle 1: 741408 I 199935 Cable winch:
Rear axle 2:
Paint/equipment: Code 1: 5345 Code 2: Code 3: Code 4: Code 5: Equipment:
SA codes
172 No code designation available 181 No code designation available
423 No code designation available 440 No code designation available
580 No code designation available 910 No code designation available
AC6 AXLE RATIO I = 3.727
C39 REAR SPRING, COMFORT, FOR 3.88-T WEIGHT VARIANT
E88 CIGAR LIGHTER
EF7 RADIO SOUND 30 W. SINGLE CD PLAYER AND 2 SPEAKERS
F68 REARVIEW MIRROR, HEATED AND ELEC. ADJUSTABLE
F76 GRAB HANDLE CO-DRIVER SIDE
H13 ADD. HEAT EXCHANGER CARGO AREA/PASS. COMPARTMENT
IL6 METALLIC FINISH
L62 CO-DRIVER READING LIGHT
LB5 THIRD STOP LAMP
M35 ALTERNATOR 14/ V 115 A
M96 FUEL PREHEATER
MS1 CRUISE CONTROL
P47 MUDFLAP FRONT
P48 MUD APRON
RF9 TIRE MANUFACTURER GOODYEAR (90)
RG5 225/70 R15 TIRES
RM0 ALL-SEASON TIRE
RS0 STEEL RIMS 6J X 15
S31 CONVENIENCE HEAD RESTRAINTS FOR PASS. COMP.
SK0 DRIVER COMFORT HEAD RESTRAINT
SK1 COMFORT HEAD RESTRAINT, PASSENGER
T74 GRAB HANDLE INTERIOR FOR ENTRANCE
U44 SEAT COVER, DRALON-VELOUR
U63 SEATING,PASS.COMP.,3RD BENCH SEAT,2ND ROW
V36 HEADLINER
Copyright Daimler AG, 09/03/10, EPC net 1.23.3.0, DW 02/2010 Delta 2 Page 1
W18 SLIDING WINDOW,FR.L. SW/CARGO AREA SLIDING DOOR
W19 SLIDING WINDOW,FR.R. SW/CARGO AREA SLIDING DOOR
XY5 No code designation available
Y43 HYDRAULIC JACK
5345 PAINT COLOR JASPER BLUE METALLIC MB 5345
SA numbers
01 522600/02 01 522601/04 01 522602/01 01 522603/07 01 522604/08 01 522605/06 01 522611/05 01 522616/08
01 522634/01 01 522636/07 01 522638/02 01 522639/01 01 522642/02 01 522644/01 01 522645/03 03 522606/02
03 522607/05 03 522608/02 03 522609/06 03 522634/01 03 522640/02 03 522641/01 03 522650/04 05 522605/06
05 522610/04 05 522619/02 05 522624/02 05 522629/01 05 522639/01 05 522642/02 07 522612/05 07 522613/08
07 522614/07 07 522617/13 07 522647/14 07 522651/09 09 522615/10 09 522617/13 13 522618/03 14 522617/13
14 522620/02 15 520059/10 15 522603/07 15 522605/06 15 522622/11 15 522630/10 18 522623/04 18 522625/03
18 522626/01 18 522627/07 18 522629/01 18 522639/01 20 522628/04 20 522632/02 20 522646/01 20 522661/06
20 522672/07 22 522643/06 22 522667/04 32 500024/05 32 504039/03 33 500021/03 33 500023/02 33 500024/05
33 500029/06 33 500323/03 33 504003/02 33 504007/23 33 504031/01 33 504032/03 33 504032/04 33 504039/03
33 504304/21 35 504000/01 35 504001/25 35 504003/02 35 504004/07 35 504005/07 35 504006/01 35 504007/23
35 504008/04 35 504018/01 39 504015/50 39 504304/21 42 504000/01 42 504008/04 42 504013/01 42 504014/02
42 504015/50 42 504016/01 42 504025/13 42 504031/01 42 504304/21 46 504039/03
Copyright Daimler AG, 09/03/10, EPC net 1.23.3.0, DW 02/2010 Delta 2 Page 2
How to: open the PDF in Acro Reader. Under Acro's "File" menu, choose "Save as..." ==> Text
Then scroll down through the resulting text file with something like Notepad or Wordpad.
Locate the 2nd three-letter code on each line, and put a line break (enter) just before it.
(yes, slightly tedious, but i did the above in 2 minutes)(whoops... i missed the first three)
The 2nd page's list of options was duplicated, so i just deleted the 2nd copy.
added: Hey! That's *my* datacard... (i thought the VIN looked familiar...) but it's what Randy posted??? :lol:
Oh, well... in for a dime, in for an Invoice...
Here's the dealer's invoice for that Sprinter. (we paid $2100 less)
(this sheet is tab-separated, which the above list isn't)
This invoice shows the *ordering codes*, not the as-built subassembly codes (above)
DAIMLERCHRYSLER VANS LLC
PLANT: DUSSELDORF
ZONE: 71
DEALER: F0104
VEHICLE ID NUMBER: WDRPD144355821254
INVOICE NO.: 5-VA6-70584792
INVOICE DT: 08/17/05
SHIPPING WT. 4501
PAID FOR BY: DCS TRUCK FINANCE
SAE HP 23.9
Equip Description Factory Wholesale Price
VA6L51 F/LINER SPRINTER 2500 HC WAGON 118"
PBM Jasper Blue Metallic 814.00
C7AA Premium Cloth Bucket Seats 348.00
ACL Accessory Group 53.00
AGH Maintenance Group 152.00
AJP Power Convenience Group 608.00
AMJ Auxiliary Front Heating Group 706.00
BAQ 115 Amp Alternator 90.00
CMB Heated Driver Seat 136.00
DGJ 5-Speed Auto W5A380 Transmission NO CHARGE
EX8 2.7L I5 Turbo Diesel Engine NO CHARGE
GEC Front Left Side Slider Window 292.00
GEW Front Right Side Slider Window 292.00
GXK 2 Additional Keys 68.00
HDC Rear Auxiliary Heater 402.00
HGM Front Insulation 175.00
LEG Additional Rt/Lt Parabolic Mirrors 52.00
NHM Speed Control 219.00
RBF AM/FM Compact Disc Radio w/Chgr Ctrl 260.00
2TB Customer Preferred Package 2TB
22B Customer Preferred Package 22B 247.00
007 DESTINATION CHARGE 880.00
msrp retail total 35,281.00
2004ret
2004ret
Would like a data card for my recently purchased 05 passenger van, VIN WD8PD644355792632 - Been a fun challenge trying to figure out all the goodies!
Thanks,
Jim
sailquik
Jim,
Send me a PM with an email address and I'll pull your datacard and send it to you as an Adobe .PDF file!
This is if someone else has not already pulled it for you.
Van_fl
Thanks to sailquik
Identification number: WDP9061551N460422 8 VIN: WDPPF4CC0A9460422
Datacard
Chassis
Sales designation: 519 4X2 4325
Order number: 7 0 750 08226
Delivery date: 10 09 2010
Paint code 1: 9147 PAINT ARCTIC WHITE MB 9147
Engine no.: 642898 41 028482
Transmission: 722683 8 219291
Steering: 1023503795
Front axle 1: 0 739097
Rear axle 1: 741416 -G 459428
Engine
Major assembly variant: A 642 010 19 45
Rear axle 1
Major assembly variant: X 004 070 304
Part var. design.: 7414160
Text ACHSE HL0 3,5TO MIT:
SCHEIBENBREMSE
Copyright Daimler AG , 4/23/13 11:10 PM , EPC 1.31.2.3 DW 03/2013 Delta 3 , User: epc14468 Page: 1
SA code
281K No code designation available
617K No code designation available
938K No code designation available
A50 FRONT AXLE WITH INCREASED CARRYING LOAD
AR3 AXLE RATIO I = 4.182
C33 REAR SPRING, HARDER
CF5 CHASSIS FOR APPLICATION D
CF6 FRONT SPRING AND DAMPER REINFORCED
CL1
STEERING WHEEL ADJUSTABLE IN INCLINATION & HEIGHT
E07
START-OFF ASSIST
E30 BATTERY MASTER SWITCH, ONE-PIN
ED8 ELECTRICAL SYST. PREINST., PARAM. SPECIAL MODULE
EE8
12V BATTERY 100 AH
EK1
EL8
TWO-WAY LOUDSPEAKER FRONT
ER0
RADIO PREINSTALLATION
ES0
JUMP START CONTACT
F68
FF5 STOWAGE BOX/TRAY ABOVE WINDSHIELD
FI1 REMOTE CONTROL KEY SYSTEM FREQUENCY 315 MHZ
FS2
EXTRA LONG MIRROR HOLDER
G40
H20
HEAT-ABSORBING GLASS ALL ROUND
HH2
ELECTRICALLY POWERED HOT-AIR AUXILIARY HEATER
HH9 SEMI-AUTO. REGULATED AIR CONDITIONING, TEMPMATIC
IG3
SPRINTER STANDARD
J58
SEAT BELT WARNING SYSTEM FOR DRIVER SEAT
J65
JW2
LAMP FAILURE INDICATOR DEACTIVATION
K60
KB0
MAIN TANK 100 LITER
Copyright Daimler AG , 4/23/13 11:10 PM , EPC 1.31.2.3 DW 03/2013 Delta 3 , User: epc14468 Page: 2
KP0 BODYSHELL SCOPES FOR SCR
L05 AUTOMATIC DAYTIME RUNNING LIGHTS FOR USA/CANADA
L90 TAIL LAMP DELETED
L94 ELIMINATION OF PARKING LIGHT
M46 14 V/220 A ALTERNATOR
MG5 ENGINE OM642 DE30LA 140KW (190HP) 3800RPM
MH1 ENGINE, LOW-EMISSION EPA 10/CARB
P47 MUDFLAP FRONT
Q18 END CROSS MEMBER BOLTED
R87 SPARE WHEEL
RH0 TIRE MAKE KUMHO
RH7 TYRES LT 215/85 R16
RM0 ALL-SEASON TIRE
RS6 STEEL WHEELS 5.5J X 16
RW4 NO TIRE REPAIR KIT AND COMPRESSOR
S04 ADJUSTABLE FRONT PASSENGER SEAT
V85 SMOKER PACKAGE
VH5 LIMA BLACK FABRIC
XY0 MODEL YEAR 0
Y43 HYDRAULIC JACK
Z44 REGISTRATION OF VEHICLE NOT POSSIBLE IN EU
SA numbers
Group 33
33 504019/91
Group 35
35 504000/04 35 504008/90 35 504019/91 35 504231/05 35 504232/15
Group 39
Copyright Daimler AG , 4/23/13 11:10 PM , EPC 1.31.2.3 DW 03/2013 Delta 3 , User: epc14468 Page: 3
39 504019/91
Group 42
42 504000/0442 504020/78
42 504008/9042 504025/37
42 504016/0842 504025/53
42 504016/10 42 504019/91
Other
Body: 3
Copyright Daimler AG , 4/23/13 11:10 PM , EPC 1.31.2.3 DW 03/2013 Delta 3 , User: epc14468 Page: 4
sailquik
Added by vic:
All,
Regards,
Roger (sailquik)
Guys/Gals,
In order to "streamline" getting your DataCard for you could you please send me a PM
INCLUDING A VALID EMAIL ADDRESS to return the card to you.
The reason for the email address is that the Sprinter-Source PM software does not like attachments and
I have found no "work around". It's much easier for me to simply email the DataCard back to you.
The "printer" feature on MBSprinterUSA EPC.net easily converts the data to a .PDF so that is not an issue here.
I'm getting a lot of requests, that's fine, I will try to be helpful here.
I'm not real comfortable with posting them to a public forum, I'll let you make that
choice AFTER I send you your DataCard.
I'm also not "collecting" email addresses for any reason. Once I return your
DataCard I delete the email address.
Roger/sailquik
