Dan_Clizer
I've just encountered something I'd like to throw out to everyone and see if anyone has had a similar issue. Just went to start my 2003 and there is no power to the starter. Instead, the fan (on the front side) of the radiator comes on. (There seems to be a fan on the front side and on the back side of the radiator)
I've had an issue with it probably 7 or 8 times over the last two years where I will go to start it and there is nothing when I turn the key to engage the starter. What has worked in the past is just to turn it off again and then turn it back on quickly.
This time is different. There is no power to the starter, it simply goes to the fan instead!
Has anyone encountered this? Any help, ideas or suggestions would be greatly appreciated!
Thank you,
Dan
Thank you,
Dan
