Old 01-21-2008, 01:11 AM   #1
sikwan
06 T1N Can
sikwan's Avatar
Default NAG1 Transmission Fluid Change
EDIT: Additional to do list in addition to a fluid change can be found here.
The T1N was a tad over 20k miles when I decided to change the transmission fluid. Nothing out the ordinary, except changing it because I had the fluid and I wanted to get rid of the additive that I recently added.
Required Tools:
- OEM dipstick
- 5mm allen wrench (possibly 4 mm also)
- 27mm socket, with 1 inch (1/4") extension, and socket wrench with pivoting head
- T30 torx bit
- 9 quarts of ATF fluid (service manual recommends 8 quarts for a full drain and fill).
Originally Posted by Added from my 2006 experience. (vic here.)
My 2006 torque converter drain screw is 4 mm Allen on the forward side of the TC.
My 2004 torque converter drain screw is 5 mm Allen on the aft side of the TC. (Less messy to drain.)
The 2006 5 mm pan drain plug was so tight I just did a tilt pan drain (messy).
Without the rear air conditioning 2 belt pulley, a standard 1 1/16" socket fits (27 mm). Actually I used a 1 1/8" 12 point. (My craftsman 1/2" drive set doesn't include 1 1/16".) ONLY rotate the engine clockwise as you face the front of the engine. (Righty tighty.)
Also there's a nice Write-up by Deancm for NCV3. Much applies to T1N's, but as one example, eg. -the frame doesn't need to be shifted for the T1N.
http://www.sprinter-source.com/forum...ad.php?t=40609
NAG1 Transmission.
Pan drain bolt to the left and rectangular rubber plugs on the bottom of the bell housing.
Close up of the rectangular rubber plugs
Remove plugs to access torque converter drain bolt.
Close up of the pan drain bolt and 2 of the 6 torx bolts that fasten the pan to the transmission.
5mm allen wrench to remove the drain bolt and a T30 torx bit to remove the 6 pan bolts.
I don't think you need a wrench this long, but this is all I had for a pivoting head. You'll see what I mean.
27mm socket, 1 inch (1/4") extension, and wrench with pivoting head.
Here's where the wrench is attached to the crankshaft bolt. Unclipped the hose attachment for full wrench swing.
It would've been easier to use a ratcheting wrench, but I couldn't get it in there without the pivoting head. Be careful to not hit the radiator fins.
DRAIN TC without using the plug?
The method below worked to drain a T1N NAG1 transmission TC and pan. I'd suggest trying it on your NCV3. If it works it's easier than messing with the TC plug even when one is included. The mentioned 7.5 qts. is about what I get doing a T1N pan/TC drain. An overnight drain will get more out than even a couple hours will. With the pan off I noticed that the fluid drips off the upper parts for quite some time = made things messy.
Assuming the ramps do the job.
To take this drain method my extra step. Use the ramps for your draining and just change the filter every other service. The filter on the T1N's was sized for "Once only at 80,000 miles" and then no more per the 2006 Operator Manual. Even knowing that "Once only" service schedule wasn't realistic, my logic is with a 40 - 60k OCI, the transmission filter is good for every other service.
Attachment 109834
Originally Posted by aaronpace View Post
First off, sorry for the wall of text below. I wasn't sure how to tell this story shorter.
So, I built myself some 6" ramps out of 2x10s (couldn't quite get myself to trust a plastic Rhino ramp for what I supposed would be long-term elevation). There's lots of room under a Sprinter, but I'm a big guy, and I like my elbow room.
With the front end elevated 6", I started draining the transmission pan. Here was my first surprise. I used my 7 quart drain pan, expecting to only get the normal 4 quarts out of the pan.
When I came back, the fluid had filled the pan to just barely under the edge. After dropping the pan and getting the rest of the fluid out of the bottom (and with what came out of the valve body), I drained about 7.5 quarts.
I had originally planned on draining the torque converter, as recommended on these forums. However, it was apparent from the amount of fluid that the converter had already drained.
The only logical conclusion in my brain is that with the front of the van up on 6" ramps, the torque converter drained back down into the transmission pan. This meant I didn't have to mess around with turning the crankshaft, digging in for the torque converter drain bolt, etc.
My short, short list of takeaways:
Driving up on ramps to drain the torque converter is way easier.
The Autel MD802 is awesome (for this vehicle).
Redoing the valve body was really easy to do with the above video help.
Happy with the valve replacements!
If I can do this, anyone can. This is my first major job on any car ever.
-Aaron
Last edited by Aqua Puttana; 03-23-2019 at 05:42 PM. Reason: Add 2006 info - I hope Sikwan doesn't mind.
The Following 51 Users Say Thank You to sikwan For This Useful Post:
158wb (10-15-2018), Actually thoughtful (01-15-2011), Alchemist_Dad (07-27-2013), benvalentine (11-22-2013), biggreen (06-19-2011), BISON (09-23-2016), Bobnoxious (05-03-2016), bru (08-22-2012), cstefan (06-06-2011), Da Tow'd (03-08-2018), DesertAdventures (01-05-2018), Dieseldoctor (09-22-2013), erviator (12-11-2012), fsneeringer (04-27-2017), GermanDieselMotorwerks (01-12-2016), GPLYNCHBURG (03-11-2019), Greendinosaur (07-06-2017), hayduke (01-14-2016), HelloPitty (05-04-2017), huskyfrk (02-02-2016), John484 (10-30-2013), jon.greco (02-26-2011), jonniboy (02-05-2014), kamaksi (04-26-2012), mad_adz (01-16-2016), maher01 (10-02-2010), mbhymer (04-11-2017), mbsprinter (10-12-2013), mything2 (10-11-2014), ncclimber7 (04-26-2018), NetDoc (10-31-2013), norson (06-06-2014), pdolan (07-26-2013), rastomiami (06-06-2015), RealityCramp (07-26-2010), sachiel (01-23-2011), seans (07-30-2010), Sgt Ret (06-03-2013), slappy (02-25-2013), smitty009 (03-10-2017), SPRINTERPETER (06-01-2017), sprintersteve (11-09-2011), Sprinter_Seeker (02-22-2017), sterling (02-18-2013), Sutil (11-12-2009), sv650k4 (02-09-2015), Thefwafwa (10-12-2014), trackstar (08-29-2015), TurtleVan (05-03-2014), unik (11-26-2014), windseye (12-16-2014)
Old 01-21-2008, 01:12 AM   #2
sikwan
06 T1N Can
sikwan's Avatar
Default Re: NAG1 Transmission Fluid Change
The service manual says to turn the crankshaft in a clockwise direction until the torque converter drain bolt can be seen. It was easier for me to turn it counter-clockwise, when looking towards the front of the vehicle, so I don't think there is any damage to doing it counter-clockwise except for loosening the nut on the crankshaft pulley. As long as the transmission is set to neutral, I don't think there will be any danger of loosening the crankshaft pulley. At least I didn't have any problem.
I shifted the transmission to neutral, laid on the ground with my feet towards the front of the vehicle and positioned my head right underneath the bell housing window. I would turn the motor while watching for the drain bolt. I would worm my way back to the front, reposition the wrench, worm back, and repeat the process until I saw the drain bolt.
Drain bolt finally appears.
5mm allen wrench to remove.
I decided to drain the pan first.
The pan drain bolt was tight on there. Copper washer was reused.
I decided to drape a plastic over the cross member before removing the torque converter drain bolt.
I'm glad I did, otherwise it would've been an oily mess.
WARNING: I didn't find the washer for the drain bolt. It might have fallen into the collection bucket, but my fishing attempts were futile. Since, I couldn't find the drain bolt washer for the torque converter and I didn't want to install the bolt without a washer, I used a brass washer I had around (plenty) that fit fine. You might want to make sure you find that washer when draining or at least purchase one to have around. I'll insert a dimension for the washer that I used.
6 T30 bolts with clips were removed to remove the pan.
Pan with some fluid left in it. The donut next to the drain is a magnet.
Wiped off a lot of metal shavings from the magnetic donut.
Metal shavings were on there like a muddy paste.
The Following 23 Users Say Thank You to sikwan For This Useful Post:
158wb (10-15-2018), Alchemist_Dad (04-24-2015), BarracodE (04-04-2013), Bigdaddydaveh (01-02-2012), biggreen (06-19-2011), BISON (09-23-2016), cstefan (06-06-2011), Da Tow'd (03-08-2018), Dieseldoctor (09-22-2013), Ewelife (04-19-2019), ewestland (07-30-2018), Greendinosaur (07-06-2017), huskyfrk (02-02-2016), JetRx (07-11-2011), long1pham (02-17-2017), mad_adz (01-16-2016), norson (06-06-2014), pdolan (07-26-2013), Sgt Ret (06-04-2013), slappy (02-25-2013), sprintersteve (11-09-2011), Sprinter_Seeker (02-22-2017), Wildmonkey (12-07-2012)
Old 01-21-2008, 01:12 AM   #3
sikwan
06 T1N Can
sikwan's Avatar
The new filter. Notice the o-ring on the tube.
Make sure the plastic tab to the right is positioned correctly when mounting.
The old filter.
A cleaned up transmission pan with new gasket.
Oops, I almost forgot the magnet.
Magnet just sticks to the steel pan.
Old filter is pulled off and the new one attached.
Filter is attached using friction of the o-ring.
The Following 18 Users Say Thank You to sikwan For This Useful Post:
bikin4fun (11-19-2014), BISON (09-23-2016), Da Tow'd (03-08-2018), Dieseldoctor (09-22-2013), DrDave (12-27-2014), Greendinosaur (07-06-2017), HelloPitty (05-17-2016), huskyfrk (02-02-2016), Johan (04-26-2013), long1pham (02-17-2017), mbhymer (04-11-2017), norson (06-06-2014), pdolan (07-26-2013), rastomiami (06-06-2015), Sgt Ret (06-04-2013), slappy (02-25-2013), sprintersteve (11-09-2011), yanny (08-09-2016)
Old 01-21-2008, 01:12 AM   #4
sikwan
06 T1N Can
sikwan's Avatar
Make sure to make a note of the pan clips.
There are a total of six, 5 of the left, and 1 of the right.
Bolts go through the holes next to the numbers.
The clip on the right goes to the forward most, driver's side of the pan. It doesn't attach to anything though.
I purchased 9 quarts of this at $7.95 a piece (shipping extra).
Filling the tranmission was a laborious task.
I first filled it with 5 quarts, turned on the engine, and set the transmission to Drive with the parking brake and front wheel chocks. Shifting it into Drive will start to pump most of the fluid into the torque converter. I then filled it with 2.5 more quarts and measured it. It was definitely low, but it wasn't at operating temp, so I went for a drive around town.
Coming back, I set up the parking brake and front wheel chocks, shifted it into Drive, and measured it. I could see the fluid just on the low side. I filled up the remaining half a quart for a total of 8 quarts (service manual recommendation on a full drain and fill), measured and was at the half way mark on the dipstick. I left it at that so that the fluid had more room to expand.
EDIT: I made a mistake with above cross out. Level must be checked with transmission set to PARK with the engine running.
The Following 36 Users Say Thank You to sikwan For This Useful Post:
bikin4fun (11-19-2014), BISON (09-23-2016), bosshogg01 (04-25-2011), Buckskinner (03-24-2013), bulur1 (02-17-2014), cstefan (11-08-2010), Da Tow'd (03-08-2018), Dieseldoctor (09-22-2013), dronsin (11-21-2015), dsul (01-30-2016), erviator (12-12-2012), GPLYNCHBURG (11-09-2018), Greendinosaur (07-06-2017), huskyfrk (02-02-2016), james h (08-30-2015), Kalifornien (11-25-2010), kamaksi (04-26-2012), komuso (05-28-2017), ktm 300 (11-23-2014), long1pham (02-17-2017), mbhymer (04-11-2017), mheat (11-19-2012), mike_mcginn (10-21-2011), mrwallysprinter (05-03-2017), pdolan (07-26-2013), rastomiami (06-06-2015), Red Eye (10-23-2012), RIC_boosted (08-17-2015), Rock (04-09-2012), SewerRatz (02-16-2014), Sgt Ret (06-04-2013), slappy (02-25-2013), sprintersteve (11-09-2011), Stani (09-06-2018), sterling (03-18-2013), w1nzr (09-28-2011)
Old 01-21-2008, 04:00 AM   #5
talkinghorse43
I think the intent of the admonition in the service manual is to turn the crankshaft in the normal direction so the slack in the chain is always taken up by the tensioner and doesn't appear on the side w/o the tensioner. Turning in the wrong direction might risk the chain jumping a tooth or two on one of the sprockets? Or maybe interference between a piston and a valve? Can't tell from your write-up whether you turned in the normal direction.
Noticed that the outside of your torque converter had a coating of fluid - maybe a seal leak?
The Following 3 Users Say Thank You to talkinghorse43 For This Useful Post:
bikin4fun (11-19-2014), kej (02-29-2016), slappy (02-25-2013)
Old 01-21-2008, 04:04 AM   #6
talkinghorse43
I purchased 9 quarts of this.
Is this MB spec 236.12 fluid? Did you measure fluid temp and correct the level target for temp?
The Following 2 Users Say Thank You to talkinghorse43 For This Useful Post:
bikin4fun (11-19-2014), slappy (02-25-2013)
Old 01-21-2008, 04:08 AM   #7
talkinghorse43
A problem with the additive?
slappy (02-25-2013)
Old 01-21-2008, 05:00 AM   #8
sikwan
06 T1N Can
sikwan's Avatar
Can't see a reason why that would happen when it's this new. At the speed that I was turning, I would be pretty disappointed (more likely using expletives) that my timing or timing chain would jump off because of turning the wrong direction.
Turning it clockwise (looking towards the front of the vehicle) will go with the direction of the motor when running. I turned it counter-clockwise.
When I pulled the rubber plugs from the bell housing, it was wet. Don't know if this is normal from production, or because of the missing washer from the drain plug. The torque converter did not show any signs of fluid leakage; essentially dry to the touch. The yellow/orangey stain on the bell housing is some type of sprayed-on rust (I think?) coating. The coating is also found in many parts of my engine.
According to Redline it is, but I'll have to double check. I know I asked them before ordering.
EDIT: http://www.sprinter-source.com/forum...3&postcount=31
I didn't measure fluid temp.
No problem found with the additive nor did it produce a solution to the RSN.
The Following 7 Users Say Thank You to sikwan For This Useful Post:
brianm343 (10-03-2017), Da Tow'd (03-08-2018), DrDave (12-27-2014), mbhymer (04-11-2017), rastomiami (06-06-2015), slappy (02-25-2013), smitty009 (03-10-2017)
Old 01-21-2008, 05:22 AM   #9
contractor
contractor's Avatar
Excellent post Seek I plan on doing my transmission in the Spring (since it is presently 10F). Thank you for the caveat pertaining to the torque converter fastener and buying a bolt and washer in advance is a nice insurance policy. My transmission access covers are also very oily too and hopefully that is cosmoline (that is what the dealer said).
T1N - 2006 Sprinter SHR 2500 140" Cargo Van, 3.72 ratio, 3-5% Bio, 21.5 MPG, 6500lbs
contractor is offline   Reply With Quote
The Following 3 Users Say Thank You to contractor For This Useful Post:
DrDave (12-27-2014), Pq1 (10-20-2011), slappy (02-25-2013)
Old 01-21-2008, 05:34 AM   #10
abittenbinder
Doktor A (864-623-9110)
Someone suggested-"turning engine CCW might cause chain to jump a few teeth on sprocket."
There are several issues regarding rotation of the Sprinter 5 cylinder engine in a counterclockwise direction(viewed head-on from front).
If you sketch a diagram of the timing chain, crank and cam sprockets and the location and orientation of the curved tensioning rail as well as its pivot point and its contact point with the chain tensioner-the kinematics become clear.
The tensioner features a mechanical spring but the pressure exerted against the tensioning rail is also supplemented by engine oil pressure when the engine is running. The engine oil pressure also feeds a hydraulic damper integrated in the tensioner. With engine off and spring tension alone acting on the curved tensioning rail(sans damping action due to possible leak down over time while stationary), the forces acting on the curved tensioning rail, during CCW turning, could defect the tensioner and the tensioning rail enough to temporarily affect cam timing-with possible though not likely, negative results.
In addition, if the engine was not then later again carefully manually rotated in a clockwise direction (after CCW rotation), the above mentioned, induced slack, could cause very high momentary stresses when the engine is restarted.
A very high mileage engine, which may be testing the span limits of its chain tensioner, would only intensify these effects.
Bottom line- please remember to turn engine CLOCKWISE ONLY. Doktor A
The Following 39 Users Say Thank You to abittenbinder For This Useful Post:
alfredo (04-06-2011), AtlasAxle (09-12-2016), biggreen (06-19-2011), Buckskinner (03-24-2013), Da Tow'd (03-08-2018), Denny Arnold (10-22-2014), DesertAdventures (01-05-2018), Dieseldoctor (03-28-2014), digger3 (12-24-2011), DrDave (12-27-2014), erviator (12-11-2012), Frank Mc (02-02-2017), galvinize (06-09-2018), GPLYNCHBURG (11-09-2018), Greendinosaur (07-06-2017), John484 (10-30-2013), jon.greco (02-26-2011), kayakkingoz (09-16-2017), kayaksagas (03-03-2016), long1pham (02-17-2017), mbhymer (04-11-2017), mbsprinter (10-12-2013), mheat (11-19-2012), mything2 (10-12-2014), NetDoc (10-31-2013), PortlandSprinterConnection (02-15-2018), puzoter (05-09-2012), rastomiami (06-06-2015), rolee (09-15-2017), sikwan (09-08-2010), skinnysim (06-04-2016), slappy (02-25-2013), smitty009 (03-10-2017), sterling (02-18-2013), surlyoldbill (05-30-2013), T1nFan (06-19-2014), toEleven (06-02-2016), Wildmonkey (12-07-2012), Zundfolge (10-07-2016)
