Problem is, they're making a sound.
With too much snow and cold to do much else, I decide to find out why my front left wheel was so grindy sounding. Steering was not impaired, and the wheel didn't feel loose, but man, did I get a rrrrrrrrrrr sound from what had been quiet tires.
So, take off the wheels.
You smart readers will notice that's the right side wheel, but I figured, why not do both while its on the lift, and I'm in the groove.
Germans being Germans, I see that a mere cotter pin in not good (or expensive) enough for holding everything together. The fancy locking 'nut' sure is slick.
Also a great time to check brake pads, clean up the calipers, lube them with brake 'grease' as necessary.
You get the pleasure of beating the rotor off the hub assembly. Since the rotor is still OK, I used pbBlaster and Mopar Rust Spray (DrA's EGR cleaner) to loosen some rust overnight on the hub area. Plastic mallet to 'work' around the rotor, not beating it to death with a sledge.
Remove the calipers from the caliper brackets- be careful with the pad sensor- and hang the caliper by wire from the strut.
You can tell I'm a bit paranoid, and don't relish replacing brake lines and bleeding brakes, so added a secondary support for the caliper. Whatever.....
