Old 08-10-2012, 11:57 AM   #1
BAK61
Default Synthetic oil
Anyone use synth. in their rig ?
Which brand ?
BAK61 is offline   Reply With Quote
Old 08-10-2012, 01:15 PM   #2
sailquik
sailquik's Avatar
Default Re: Synthetic oil
BAK61,
The Mercedes Benz BEVO (listed in your Operator's Manual that normally comes in the glove
box in a new Sprinter) suggests there are very few non-synthetic motor oils that will work in
a Sprinter and they recommend a shorter (< 10,000 miles) oil change interval if you do not use
a full synthetic oil.
If you want to use the "most recommended" oils (and what knowledgeable dealer service
shops use) you need to get the following FULL Synthetic oils for use in your Sprinter.
If you have an '02-'06 MB/Dodge/Freightliner Sprinter T1N with the inline 5 cylinder 2.7 liter
diesel engine (OM-612 and OM-647) the absolute best oil is:
Mobil 1 0W-40 European Car Formula
This oil Meets or exceeds MB BEVO 229.5
If you have a later '07-'12 MB/Dodge/Freightliner NCV3 Sprinter with the 3.0 liter V6 (OM-642)
engine the best oil is:
Mobil 1 5W-40 ESP Formula M (Emissions Systems Protection). This is a low ash oil specially
formulated for use in diesel engines that use the Diesel Particulate Filter.
This oil Meets or exceeds MB BEVO 229.51
The latest Sprinter V6 NCV3's also have the exhaust after treatment and need to have the
DEF tank filled about every 10k miles.
If you are thinking of using regular non-synthetic oil I tink most here on the forum would strongly recommend against doing so.
BAK61 (08-13-2012)
Old 08-13-2012, 01:21 PM   #3
BAK61
I am a believer of synthetic oil.
AMSOIL is my preferred choice
I'll wait til I get the van to really research this
Old 08-13-2012, 01:39 PM   #4
jdcaples
Not Suitable w/220v Gen
jdcaples's Avatar
Synthetic oil
Which brand ?
That you're wondering if conventional, non-synthetic engine oil is common - or even ok - for a new Sprinter engine indicates you have your work cut out for you.
http://bevo.mercedes-benz.com
is an extranet repository for MB's records of "who complies with our fluid specifications," as well as the physical properties required to "pass the test."
I would start with the latest owners manual available for Sprinters. There are PDFs in NCV3 database as well as here: http://www.mbsprinterusa.com/owners/manuals
As you read, you'll see specifications like MB229.51. 229.51 is defined on bevo.mercedes-benz.com.
-Jon
PS: I'm assuming that you want the most out of your Sprinter and that you're willing to do the homework to either DIY or at least trust, but verify your dealership's work.
BAK61 (08-26-2012)
Old 08-13-2012, 03:51 PM   #5
bcislander
'07 Mercedes-badged Dodge
bcislander's Avatar
snip....
I'm not sure how you define the "best oil", but, at the risk of starting yet another 'oil war' , Valvoline SynPower MST 5W-40 VV966, also meets or exceeds MB BEVO 229.51
You are almost certainly correct in saying that the Mobil product is the most commonly used in NCV3 Sprinter diesels that have the correct spec oil in the sump.
I agree 100% with your last statement.
2007 Mercedes-badged Dodge GWV Legend
bcislander is online now   Reply With Quote
The Following User Says Thank You to bcislander For This Useful Post:
BAK61 (08-26-2012)
Old 08-26-2012, 01:56 PM   #6
BAK61
I do have a lot of research to do, but I'm cool with that. I'd rather research something to death than make an impulse (wrong) decision.
i still have to make it to one of the big shows to see the RVs in person, and somehow take a test drive.
We love the layout of the LV products, and the reviews are very high.
When we started researching Class Bs, we were sure Roadtrek was the way to go. We are amazed how LV can squeeze a studio apartment into a Sprinter van.
Hope to see you all on the road someday. B
first I need to sell my house
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
