Expert Marine
Electronics
I try to manually up shift to keep the RPM's down, but it doesn't seem to respond right away. It also doesn't seem to respond with concistancy.
What does your van do?
The "manual shift" commands are more of a "suggestion" to central command that you want shifts now. Sometimes it will take your advice-other times it knows (or thinks it knows) best. If you're really impatient with its response time, try holding the stick -for a few seconds- in which ever direction you wish the shift to go. That seems to get attention. Doktor AI try to manually up shift to keep the RPM's down, but it doesn't seem to respond right away. It also doesn't seem to respond with concistancy.
In the 2007, it will upshift to 5th or downshift to 1st (from whatever gear you are in) if you hold it in the correct direction for a few seconds.If you're really impatient with its response time, try holding the stick -for a few seconds- in which ever direction you wish the shift to go. That seems to get attention. Doktor A
Excellent point Ken. Throttle position(load demand by driver) is an important parameter and will get central commands attention. Doktor AHerr Doktor..... I agree with you, and would add this: If you want an upshift it will get more attention in the grand scheme of Sprinter computer control if you also let off of the accelerator slightly!
This is by my own experience, not by technical analysis of the engine/transmission program.
KenB
