Closed Thread
Old 07-01-2011, 06:55 PM   #1
bigdawg
Thumbs up FOR SALE : 2004 SprinterAirstream Westfalia
2004 Sprinter Airstream Westfalia
Offered for Sale : 58,500.00
An incredibly practical camper-van, a self-contained unit that you can park in a standard size parking space. It has received gentle use & has been conscientiously & professionally maintained. Sale due to limitations from back surgery. Clean in & out, a head-turning classic touring coach.
Brochures:
http://dl.dropbox.com/u/6232178/Airs...ochure%201.pdf
http://dl.dropbox.com/u/6232178/Airs...ochure%202.pdf
TECHNICAL SPECIFICATIONS
Model: Airstream Westfalia
Chassis: 2500 Mercedes-Benz Sprinter Van w/unibody construction
Engine: Mercedes Benz CDI Turbo Diesel 2.7 liter 154 HP @ 3800 RPM
Transmission: 5 speed automatic with overdrive, 244 lbs. torque @ 1600-2400 RPM
Brakes: 4 wheel disc brakes w/ABS system
Wheelbase: 140"
Michelin Radial Tires with alloy wheels
Turning radius: 21'
Gross combined weight rating (GCWR): 13,550 lbs
Gross vehicle weight rating (GVWR): 8,550 lbs
Unit base weight (UBW): 7,100 lbs
Net carrying capacity: 1,450 lbs
Towing capacity: 5000 lbs
Hitch tongue max weight: 500 lbs.
Towing hitch
Diesel tank capacity: 26.4 gal
14V/200-amp alternator & 2 auxiliary 85 amp hour gel batteries
Belted Seating capacity: 5
Sleeping capacity: 4 (sleeps two up top & two below)
Fresh water tank w/drain: 26.4 gal
Water heater (LPG manual light): 3 gal
Holding tank: Gray Water 18.5/Black Water 9.6 gal
LPG with remote fill: 33 lbs
Patio Awning: Fiamma
DIMENSIONS
Exterior length: 18'5"
Exterior width: 6'3"
Exterior height with a/c: 11'
Interior head room (sofa location, living area): 7' 9"
Interior width (floor): 5'8"
Cabin door width: 3'5"
INTERIOR DRIVER COMPARTMENT
Swivel seats for driver and front passenger
Driver & front passenger air bags
3-way adjustable driver seat
3-point seat belts w/ extension & head restraints Automotive air conditioning / heater
AM/FM w/ mp3 player input / Sirius Radio
Power windows & mirrors
Cruise Control
LIVING/SLEEPING AREA
Large power skylight with remote & rain sensor
Integrated screen/shades on all windows
Heat insulated vent windows in roof
Laminate countertops
Washable durable vinyl flooring throughout
Storage racks in rear doors
Built-in lockable safe
Roof bed - 6'6" x 4'8" w/ high comfort springs & safety net - comfortable!
Sofa - converts into a 6'4" x 4'2" double bed
Large removable dining table & side folding table
KITCHEN
Laminate cabinets and galley top with backsplash
Stainless steel sink w/ glass cover & chrome faucet
Pull-up stainless steel draining board
BATHROOM
Complete wet bath with shower, hand basin, storage cupboard, large mirror and toilet - shower/faucet unit recently replaced w/ new equipment
Roof vent
Outdoor shower hookup, hose & nozzle w/ mix valve
APPLIANCES
Twin burner stainless steel gas stovetop & range vent
2.1 cubic feet refrigerator & freezer
3 gallon LPG water heater
Microwave
Low profile 110/12V Kerstner air conditioner
Cable TV & telephone hook-ups (1 each)
17" LCD flat panel TV w/ DVD & USB streaming
Smoke, carbon monoxide & LPG detectors
Airtronic diesel-power auxiliary heating system w/ timer - needs service
110 Volt inverter
ELECTRICAL - FUNCTIONAL
Power lock doors w/ remote keyless entry
External waste & water connections
Main switch for 12V supply and water pump (new H2O pump)
12V fluorescent lighting w/ RFI ballast under overheads
2.5KW generator w/ remote start, LPG powered (ONAN)
30 amp service (includes 50 amp 25' power cord)
Central control & monitoring panel: heating, refrigerator & freezer, water tank levels & battery
TECHNOLOGY AND SAFETY
ESP - Electronic Stability Program
BAS - Brake Assist System
ASSYST maintenance monitoring system
Fire extinguisher
Front independent suspension w/ front & rear stabilization bars
Heavy duty front & rear shock absorbers
Four wheel ABS & disc brakes
EBD (Electronic Brake Force Distribution)
Acceleration skid control
Replacement Parts - engine hoses, fuses, pump
Back up camera
8' Aluminum collapsible step ladder - stores away
Recently Serviced by Dr. A - Service records
CURRENT MILEAGE (July 2011)
63,000 Miles -Mechanically Sound
Images to follow after the 4th of July weekend
Steve & Debbie McKinney
Conway, NH 03818
603-447-3372
mckfam@ncia.net
bigdawg is offline
Old 07-01-2011, 10:00 PM   #2
hayduke
2005/2006 leisure travel
Default Re: FOR SALE : 2004 SprinterAirstream Westfalia
Wow.So a 2005 Leisure Travel FreeSpirit LSS 158" with 42000 miles at 37.000 is a good price,eh?
hayduke is offline
Old 07-01-2011, 11:35 PM   #3
bigdawg
Just paying attention to the market numbers.
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=130507844292&viewitem= &sspagename=STRK%3AMEWAX%3AIT#ht_2060wt_1167
bigdawg is offline
Old 07-02-2011, 03:41 PM   #4
tfrazie
tfrazie's Avatar
That's a fair asking price BigDawg! Especially considering the very short supply (only ~200 in the US, the incredible utility, a 500,000 mile engine, a cult like following and relatively recent ebay selling prices near yours and higher (in a least one case that I saw). I've also seen a few sell in the high 40's too. I concluded either the sellers didnt know all of the above or were highly motivated to sell. Good for those buyers! Value is always in the eye of the beholder. Good Start! Good Luck!
tfrazie is offline
Old 07-03-2011, 04:19 PM   #5
minigoogoo
minigoogoo's Avatar
I suppose that is a good price if that is what you want. I'm definitely not a student of that particular brand or model, but suspect you got a great deal. Congrats on that!
However, in all fairness, the Westy is an entirely different concept and represents a very different philosophy in terms of build and utility. About the only things these two vehicles have in common is that they are both campers and they both roll on a Sprinter chassis.
Of course, as Tim points out, relative scarcity and basic market forces will ultimately be big contributors to value. On the used market, the Westy has a pattern of outperforming the more common Class B brands-- possibly because the balance of the brands are more like one another, and collectively create a much larger supply of similar vehicles. This is not to say that they are all the same, or that the quality and features are identical. The balance of the 'Bs' are simply more similar in concept-- horizontal plan layouts, with more or less standard domestic camping components, within the factory Sprinter shape.
For us, the Westy fills a series of unique needs. Sleeps 4, on two separate beds. Seats 5, with the kiddos sitting forward and close to the grown-ups in the front seats. Fits in a standard parking space, allowing us to occasionally use it for errands or commuting. The conversion components and quality are exceptional. The utility of available space is unmatched, partly because the van goes 'vertical', as opposed to spreading out horizontally on a longer chassis with less headroom. Just my ...
Steve, to date, I've purchased two Westys (and sold one of them). Over the years, I've watched many listings come and go, and I know this small market very well. Assuming the van is in great shape, your asking price seems fair, especially during camping season. Good luck!
(Airstream) Sprinter Westfalia #189 (SOLD)
(Airstream) Sprinter Westfalia #059 (SOLD)
(Airstream) Sprinter Westfalia #068 (YES, I AM CRAZY )
minigoogoo is offline
Old 07-12-2011, 03:49 PM   #6
bigdawg
Thumbs up Re: FOR SALE : (2004 build year) 2005 SprinterAirstream Westfalia
Originally Posted by bigdawg View Post
2005 (2004 build year) Sprinter Airstream Westfalia
Offered for Sale : 58,500.00 $55,500.00
Brochures:
Wheelbase: 140"
Turning radius: 21'
Towing hitch
DIMENSIONS
Cruise Control
KITCHEN
BATHROOM
Roof vent
APPLIANCES
Microwave
110 Volt inverter
Fire extinguisher
Back up camera
Images E-Mailed upon Request
Conway, NH 03818
603-447-3372
mckfam@ncia.net
Last edited by bigdawg; 07-12-2011 at 03:54 PM. Reason: Price Change - correction in dates - add images
bigdawg is offline
Old 07-24-2011, 06:20 PM   #7
bigdawg
Default Re: FOR SALE : (2004 build year) 2005 SprinterAirstream Westfalia
Asking price reduced to a firm $52,000.00, we are preparing to take this vehicle off the market and travel with it this winter.
bigdawg is offline
Old 08-16-2011, 08:54 PM   #8
bigdawg
$49,750 ~ August 2011
Let's make a sale, make us an offer.
bigdawg is offline
Old 03-02-2012, 04:02 PM   #9
bigdawg
This Vehicle Sold 9/2011 for $46,750
bigdawg is offline
The Following 2 Users Say Thank You to bigdawg For This Useful Post:
MERLEANDSARAH (07-04-2013), Toddius (09-21-2015)
Closed Thread
