Old 03-25-2011, 09:54 PM   #1
briggie
2007 3.0 diesel
Default oil level help on dip stick
my oil sensor has been broke now for a while and because of that it does not tell me on the dash how much oil i have,, my question is when i check my oil cold in the morning it is full on the dipstick,, when i drive when it is warmed up there is nothing on the dipstick and that is almost 2 quarts,, i check it every time i fill up and it is always the same, cold full warm empty. is everyones like that
briggie is offline   Reply With Quote
Old 03-25-2011, 11:05 PM   #2
knighty
knighty's Avatar
Default Re: oil level help on dip stick
did you leave it for 5 min before you checked it hot ?
it takes a while for the oil to run back down into the sump :-)
knighty is offline   Reply With Quote
Old 03-25-2011, 11:25 PM   #3
Altered Sprinter
Altered Sprinter's Avatar
This is why your manual states hot or cold temperature related on your dipstick.
Red = Hot/Blue = cold/ and yellow the latter is exceptionally rare.
Richard
No Shalam - No Shalom
Old 03-25-2011, 11:41 PM   #4
piper1
Resident Oil Nerd.
piper1's Avatar
If it is between the marks when the engine has sat (level) all night, you are fine.
It takes a while to drain back when you shut the engine off...and you will overfill it. That's bad. High oil levels lead to more oily crankcase gasses, which get sucked in, along with EGR, to the intake. Makes a hell of a mess of the intake swirl valves.
I had a.....2008 NCV3 (badged as Freightliner) 170wb ext body 6 foot roof. 12 feet for cargo, 42 inch bunk sealed off from the back, battery powered A/C and 120 v power and Air Tabs! Flettner Roof Vent....but it's gone.
298,000 km on the clock (06/22/11). Valvoline SynPower MST, Shell ATF134
Now driving a CargoMax 600.
piper1 is offline   Reply With Quote
Old 03-26-2011, 01:26 AM   #5
briggie
2007 3.0 diesel
i do have the red dip stick and still is the same, and also what does the swirl valves do,
