Old 01-21-2011, 01:28 PM   #1
madtom
Default torque specs/tightening sequence
Anyone know where I can get the torque specs/tightening sequence for the intake and exhaust manifold on a 2005 Diesel Sprinter? Any help is appreciated. Thanks.
madtom is offline   Reply With Quote
Old 01-21-2011, 04:48 PM   #2
Default Re: torque specs/tightening sequence
From the 2006 service manual (get it from http://www.mediafire.com/?tzy2jbomzjz )
Exhaust manifold nuts at cylinder head: 30 newton-meters ( 22 foot pounds) (page 9-13)
but then on page 9-15, the table says
Exhaust Manifold to Cylinder Head: 29 N-m ( 21 FtLb.)
In the quite busy table, i don't see an obvious "Intake Manifold" spec.
Ahh... page 9-68 (notice they're using INCH-pounds in the following):
Tighten (intake) manifold bolts to 16 Nm (142 lbs. in.) in a cross directional pattern beginning with the middle bolts and tightening outward to the ends.
then:
Install the rear intake manifold bolts and tighten to 16 Nm (142 lbs. in.) (Fig. 70).
(4) Install the lower intake manifold support bracket. Tighten bolts to 20 Nm (177 lbs. in.) (Fig. 70).
All they say for the Exhaust Manifold is (page 9-70):
(4) Position the exhaust manifold over to studs and tighten retaining nuts to 30 Nm (22 lbs.ft.).
...no tightening order given
alfredo (03-11-2011), madtom (01-24-2011)
Old 01-24-2011, 04:32 PM   #3
madtom
Is it the same for an 06 as it is for the 05?
Old 01-24-2011, 06:09 PM   #4
madtom
[QUOTE=autostaretx;121898]From the 2006 service manual (get it from http://www.mediafire.com/?tzy2jbomzjz )
Finally, a link that works! I also had to download a program that would open the file for me since it is archived, but I found one that was free so that's cool. Got it downloaded after numerous failed attempts on all the other posted links. Don't know what was up with those. Just couldn't get them to work for me. Anyway, just wanted to say thanks!
Old 01-14-2016, 07:17 PM   #5
slackey
anyone have the torque specs for a 2003 2.7l
slackey is offline   Reply With Quote
Old 01-14-2016, 08:34 PM   #6
Both the full 2003 and 2006 service manuals are available here: http://aie-services-2.net/Sprinter/
(Early in Chapter Nine are the engine torques)
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
