Old 09-17-2010, 06:32 PM   #1
silverstar84
Default DPF-Diesel Particulate Filter-Clean or Replace
My 2007 Sprinter has a check engine light due to “soot content to in DPF”.
It was thought I could drive it out. I tried and started with a 37g soot content.
It is down to 13g but it should be less than 8g.
Some research has brought some things to my attention that may be helpful for some here.
1st, depending on who you deal with, list price for a new DPF is $3800.00
2nd, used DPF’s are in high demand and hard to get your hands on.
3rd, Dodge informs me that you have to provide your old DPF or Catalytic Converter or be charged a core. Not to be confusing but they do not offer rebuilt they just want the old, I am guessing for the material in them. Freightliner is much less.
4th, on this forum someone mentioned having them cleaned.
I goggled “DPF clean” and found some places.
In my reading I came across a couple of manufactures promoting DPF cleaning machines. They were promoting to Fleet operations and in there pitch the machine cost $20k and they could charge $450 for each clean and how long it would take to pay for it.
Seems they will do anything from a 5inch dia DPF up to a 38inch dia off a crane.
So I started calling all the big fleet operations locally and found a new, state of the art, truck center here in town and they will take walk in DPF cleaning. $475
I am going to give it a try.
5th, I have included some pic’s of my DPF, inlet and outlet.
Everyone that know’s much about these comment on how fragile they are, ceramic.
Around 5% are not cleanable either due to it being cracked, or housing damaged, or so much oil being burned that it penetrates the small openings in the DPF and plug it so bad that it creates a cold spot, I assume this is like an insulation and cannot get hot enough to melt.
Also, if wrong oil is used, as mentioned here on the forum, the metal particles can add to or increase the possibility of not being repaired.
I am taking mine for a cleaning today. Much like waiting for the doctor to call, I hope the news will be good.
Michael
silverstar84 is offline   Reply With Quote
The Following 15 Users Say Thank You to silverstar84 For This Useful Post:
chrispsprint (01-24-2017), CJPJ (09-18-2010), dave61 (07-27-2015), Deancm (04-09-2015), Dieselhawk (08-13-2013), falkor (05-23-2014), fishermunn (09-18-2010), GPLYNCHBURG (02-04-2019), LOTUS (07-28-2015), LuckyEarthling (06-05-2015), nikolay0630 (09-18-2010), piper1 (09-18-2010), shanemac (09-17-2010), suzieque (09-17-2010), Twromerojr (04-12-2016)
Old 09-17-2010, 09:12 PM   #2
flman
Fast and sloppy typist
Default Re: DPF-Diesel Particulate Filter-Clean or Replace
Try a Cummins service center. I was at one a year ago, and they had a sign that advertised DPF cleaning services.
The Following User Says Thank You to flman For This Useful Post:
Old 09-17-2010, 09:33 PM   #3
suzieque
I'm guessing dpf cleaning services will become more and more common. How did you measure the soot mass? I have a dashhawk and it shows soot mass, but I'm skeptical about its accuracy.
suzieque is offline   Reply With Quote
Old 09-17-2010, 11:41 PM   #4
shanemac
Thanks for the pics its interesting to see what is looks like inside there.
That sounds crooked...if they want the material in them or any part of the DPF they should be coughing up the money for it...if your buying one outright.
When you go to reinstall DPF will you just use exhaust clamps so it can be removed easier down the road? Also some pics of were you made your cuts in the exhaust would be handy.
shanemac is offline   Reply With Quote
Old 09-17-2010, 11:50 PM   #5
Chandlerazman
Chandlerazman's Avatar
What happens if you just hollow it out? (Besides belching smoke upon acceleration!) Will it adversly affect the computer? Can the computer be programmed to bypass it?
Chandlerazman is offline   Reply With Quote
Old 09-18-2010, 12:53 AM   #6
I once witnessed a plugged catalytic converter from a Dodge van get "rodded out" with a long 1/2" rod and hammer. The ceramic came out in honeycomb chunks. It was just as illegal as gutting a DPF would be. Back then the emisions test was basically a visual "parts in place" inspection.
Actually I doubt there would be excessive belching of smoke. Even ignoring the environmental implications and vehicle regulations, I gotta believe the computer would notice the system changes. vic
Bobnoxious (10-01-2016)
Old 09-18-2010, 01:40 AM   #7
kendall69
Here in Ca. you now have to go for a smog check on diesel vehicles. I never knew that, but sure enough. I took it in and asked the guy, what the heck are you checking for? He said it's just a visual inspection.
Being ceramic and soot, I'm thinking they have some heavy duty grill cleaner that I've seen them use on the bottom of a badly burnt pan at the fair. Also commercial kitchens have some major grill cleaner stuff. I mean who knows. Before I turn it it in I would experiment on the old one if there are no commercial cleaners.
$3,800.00 buck ARE THEY NUTS, that's half the price of a new engine. Heck it's a deposit on a new one.
2007 144" Diesel
Old 09-18-2010, 02:23 AM   #8
silverstar84
SDS or Mercedes computer, it wants to see less than 8g.
I would think the SDS or dashhawk or DRPIII computer is reading information gathered from an onboard computer.
Old 09-18-2010, 02:25 AM   #9
silverstar84
When you go to reinstall DPF will you just use exhaust clamps so it can be removed easier down the road? Also some pics of were you made your cuts in the exhaust would be handy.[/QUOTE]
There are no cuts, fancy and user friendly clamps and brackets. Very easy to remove.
Old 09-18-2010, 02:30 AM   #10
silverstar84
$3,800.00 buck ARE THEY NUTS, that's half the price of a new engine. Heck it's a deposit on a new one.[/QUOTE]
Last time I checked, the V/6 diesel engines, used, are bringing $10k.
But still, $3.8K is a budget buster any way you look at it.
The more I read the more I see this becoming more and more needed.
If so, the prices should come down.
The Following User Says Thank You to silverstar84 For This Useful Post:
dslcoach (04-08-2013)
