Old 01-18-2019, 10:06 PM   #31
Hoosier 45
Default Re: general plywood thickness for cabinets
I used 1/4" Baltic birch for all of my cabinets and the short queen sized bed. Great stuff, light, strong, stiff and straight. I used full length glue block in every corner. Then screwed and glued.
Hoosier 45 is offline   Reply With Quote
The Following User Says Thank You to Hoosier 45 For This Useful Post:
CJPJ (01-18-2019)
Old 01-18-2019, 10:43 PM   #32
Island Jim
Check out Apple Ply at Cross Cut, used 1/2" and 1/4" in my cabinets. Very nice material but expensive. I am also on Vashon send a message if you want to check out our van.
Island Jim is offline   Reply With Quote
Old 01-19-2019, 12:05 AM   #33
flyag1
Here is what I've been doing:
I cut the bottom using 1/2 Russian birch, it's a 7 ply and very stable strong.
Then I take 2" wide strips of the same birch and glue / nail brad this 2" piece to the outside edges of the bottom of the drawer.
Basically now I have a box that will become a draw except the sides are only 2" tall.
Finally I wrap another ring of 1/4 around the outside of the 1/2 thick base and glue and brad it together. Cut this piece as tall as you want the finished draw.
You can cut the 1/4 as tall as you like. I have some drawers that are 12" tall.
Attaching the corners of he 1/4 ply can be accomplished by clueing 1/2 square stock into the joint. Done:
flyag1 is offline   Reply With Quote
