Old 08-13-2018, 12:00 AM   #31
Default Re: Rear Differential gear oil change
MB usually uses 14mm, VW has used 17mm from my previous experience. I would measure, but you can use a couple of nuts stacked on bolt, combined with a regular wrench. Easier than buying a new hex key.
Old 08-18-2018, 02:21 PM   #32
Mickyfin
Mickyfin's Avatar
Turned out it was 17mm in the end, refreshed the differential oil, but the whining sound I get when I reach 100kmh is still preset, but only there whilst accelerating.
From what research I've done, it is possible the propshafter centre bearing? The whining sound I hear when I hit 100kmh whilst accelerating sounds like its coming from the rear of the van.
Mickyfin is offline   Reply With Quote
Old 08-18-2018, 03:04 PM   #33
Mickyfin
Mickyfin's Avatar
Bit of an update, I've put the van in neutral, and handbrake on, and then got under the van to check the UJ's, and bearings, and these are all solid, and actually look new, so now, I suspect the whining sound is a wheel bearing, as I'm also getting some brake squealing from one side at the rear, does this sound plausible'?
Old 11-26-2018, 10:37 PM   #34
The Heaven Van
Originally Posted by sailquik View Post
Curious Sprinter Tech,
Are you sure about this?
Here's a photo of the MOPAR Rear Differential Fluid most recommended for '02-'06 T1N Sprinters:
http://www.ebay.com/itm/SPRINTER-AXL...-/330355238354
You can see that it says "Sprinter" right on the label!
For the later NCV3 Sprinters (906 series NAFTA) the MB BEVO 231.2 Page 2 says
for 906 (NAFTA Sprinters to use MB BEVO 235.8!
Here's a link:
http://bevo.mercedes-benz.com/bevolisten/235.8_en.html
No where in all of this MB official information can I find any reference to
"75W-140 synthetic Gear oil".
All of the above indicates 75W-90 synthetic hypoid oil or 90W hypoind gear oil.
The MOPAR product may not be synthetic as it carries no MB approval number, but
it was recommended lube for Dodge T1N Sprinters ('02-'06) and used by most knowledgeable
Dodge Sprinter dealers.
The later NCV3 Sprinters (906) all need "synthetic 75W-90.
Hope this helps,
Roger
Roger - Can you confirm that 2007s call for a differential fluid change as well. Im going over maintenance tasks and did not think to change the dif fluid in our 2007. If I recall the 2007s are missing some options in the later models - but i am assuming I should still be replacing the dif fluid every so often. (Im sure what I am thinking is missing in the 2007 relates to emissions and not drive train) - If so Im looking up how to and changing the dif fluid asap.
Thank you as always.
The Heaven Van is offline   Reply With Quote
Old 11-28-2018, 05:11 AM   #35
sailquik
sailquik's Avatar
The Heaven Van;
Do you have the original Owner's/Operator's Manual that came with your Sprinter?
If you do, the full maintenance schedule is most likely listed.
These manuals may still be available online at the Dodge or Freightliner Owners manual sites.
The books are identical, the Dodge manual says Dodge throughout and the Freightliner is identical except it
says Freightliner throughout.
Looks like you can download the 2007 Owner's Manual for free at this site:
https://manuals.co/workshop/mercedes...rs-manual/2312
Maybe someone on the group has a 2007 USA Spec Sprinter Service booklet.
That would have specific info on the recommended frequency for changing the rear differential gear lubricant.
IMHO, since it's very easy to do, and it's also easy to find the approved lubricants, it's probably wise to change
it every 60k miles or maybe 75k miles.
See what the manual has to say.
Here's some more info specific to your question:
https://sprinter-source.com/forum/sh...+Owners+Manual
Another question.....if you have a 2007 Sprinter, why are we discussing this in a the T1N specific forum section?
Roger
2014 Sprinter 516 series (3500 DRW) 170"/4325 mm wb Hi Top Short Back
OM-651 I4 2.143 liter two stage turbo charged with 36.9 PSIA MAP Limit Valve
7 Speed 7G-Tronic, manually shiftable, automatic transmission.
OEM back up camera, Bi Xenon light package, fog lamps, headlight washers.
Had 2006 T1N 3500/158|2010 NCV3 519/3500/144|2011 & 2012 NCV3 519/3500 170
Old 01-10-2019, 06:57 PM   #36
biggreen
I called my local stealership. They want $45 per quart of the sprinter specific gear oil. Umm...
So i found the 2005 service manual and looked at the lubrication section.
http://diysprinter.co.uk/reference/0...e%20manual.pdf
Copied from the manual:
REAR AXLE
• Synthetic Gear & Axle Lubricant SAE 75W-140
Quantity: 1.8L (4.0 pints)
biggreen is offline   Reply With Quote
Old 01-10-2019, 08:14 PM   #37
LuckyDawgz Jim
LuckyDawgz Jim's Avatar
REAR AXLE
Yeah, I bought 75W-140 Synthetic, non-MB Gear lube, drained the muddy mess out of my 2002 and it's been fine the past 5 years.
*NOTE my Sprinter has a screwed in fill plug, which was a beast to get out... To avoid not being able to refill it, check to see that you can get the fill plug out, BEFORE you drain it!
2002 Freightliner C2500 SHC 158WB 113k
RV Conversion... Known as the "T1N TeePee" or "White Whale"
LuckyDawgz Jim is offline   Reply With Quote
