Old 06-01-2017, 09:42 PM   #1
David Brown
Default ID Parts has DPFs and other things
Hi-
I hope that this is an appropriate place to post this. I have been using ID Parts in Hingham, Ma (IDparts.com) to supply me with parts for my 2004 VW diesel Jetta wagon for years. They have oem and upgrade parts with fast shipping and just all around helpful, friendly service.
They have recently added a number of Sprinter parts including DPFs,($1320 net when core is returned) EGRs, Ad-blue heaters, oil change kits. They are adding more parts as well (when I called to ask them if they could obtain a DPF for my 2013 Sprinter they said that they had just posted it -while I was on hold).
I have no connection with this firm, other than that of being a long term satisfied customer.
David Brown
Barnstead, NH
David Brown is offline   Reply With Quote
The Following 2 Users Say Thank You to David Brown For This Useful Post:
edfrompa (06-01-2017), smiller (06-01-2017)
Old 06-01-2017, 09:56 PM   #2
CJPJ
2008 3500 170"ext. 3.0 V6
CJPJ's Avatar
Default Re: ID Parts has DPFs and other things
http://www.idparts.com/
The Following User Says Thank You to CJPJ For This Useful Post:
Old 06-01-2017, 10:29 PM   #3
smiller
2008 View J (NCV3 3500)
Good prices. Does anyone know if these are all real OEM parts or substitutes? It doesn't really state very clearly in the descriptions.
Old 06-01-2017, 11:21 PM   #4
David Brown
Hi-
I have only ordered the DPF. It looked the same, but I didn't examine it very closely while the old one was next to it. I had a local garage put it in (for $268) and they said it was an exact replacement. The van runs much better, but it is still setting DPF codes- inefficient and full every 650+- miles (before was plugged at 300 miles) Mileage has gone back up to normal (from 18.5-19 to 20-22).
All of the VW parts that I have ordered from them have clearly been OEM when stated to be so. The non-oem parts are labeled as such and are usually an upgrade in longevity and/or performance.
David Brown
Barnstead, NH
Old 06-01-2017, 11:31 PM   #5
CJPJ
CJPJ's Avatar
You must have missed it;
$840.00
Diesel Particulate Filter (NCV3 OM642 Early)
OEM Mercedes-Benz
OEM Part Number: 9064901592
Manufacturer Number: 9064901592
Old 06-01-2017, 11:32 PM   #6
smiller
Ya, eyes not working as well as they used to I guess
Old 06-01-2017, 11:55 PM   #7
Bobnoxious
Bobnoxious's Avatar
Better than mine, I could not find any DPF for sale.
File Type: png Screen Shot 2017-06-01 at 4.03.17 PM.png (58.1 KB, 54 views)
Old 06-02-2017, 01:24 AM   #8
icarus
It would seem if you are still throwing codes, you might be in for another plugged DPF if you haven't solved the underlying problem?
Icarus
Old 06-02-2017, 01:53 AM   #9
smiller
Or he may just need to perform the parameters reset procedure required when a new DPF is installed. I imagine that failure to do this could result in erroneous fault codes. Without an advanced scanner I guess a dealer would have to do this.
Old 06-02-2017, 02:09 PM   #10
David Brown
Can you explain the parameters reset you speak of? A new DPF must be introduced to the computer? Other than a dealer, what scanner is able to do this on a 2013 model?
Thanks,
David Brown
Barnstead, NH
dpf, egr valve
