Old 10-29-2011, 12:03 AM   #11
geoffs
2003 T1N 316CDI LWB
geoffs's Avatar
Default Re: L Track, Fittings and Straps
Originally Posted by Charliektm400exc View Post
I just priced some L track this week in Hobart from the ANCRA distributer, $100 a metre approximately, and he told me he was only adding $7 margin on it. (39" for those metrically challenged), so that makes it about 4 times the price from America.
Charlie
FYI I got my quote from Norden who are the Sure-Lok distributor in Australia.
Quote was for 100" (2.5metre) lengths.
I might go and have a look at sail track. It's readily available and much more reasonably priced (despite the 'marine' tag). Anyone use this in their Sprinter?
[Sorry for getting off topic]
Geoff
geoffs is offline   Reply With Quote
Old 10-29-2011, 01:37 AM   #12
Mrdi
Mrdi's Avatar
I took a look at Harken and Ronstan before I did the L Track as posted above. Here in California the sailing gear was much more expensive.
The aircraft quality L track (2) 48" sections, drilled w/ stainless mounting bolts and nylon locking nuts were about $90
including shipping and 4 quick release fittings.
http://www.car-truck-accessories.com/coretrax.asp
Mrdi
2008,2500, 144 Hi Cargo
Surf City USA,
Southern California
Old 10-29-2011, 01:59 AM   #13
Altered Sprinter
Altered Sprinter's Avatar
Mercedes Benz Hidden portal... Not for customers to see.
There is retail ...there is Trade pricing.
Do you want to raise your floor Or arrange for roller slide lifts.
Got to love Canada
Richard
No Shalam - No Shalom
Old 11-08-2011, 12:04 AM   #14
seans
seans's Avatar
A few L-track questions for Rob:
I see you have end caps for the flanged track. Do you have end caps for the angled and recessed track? If not, can the puck from the single stud fitting kit be cut in half to make an end cap for the angled track?
Also, while researching this, I realized that in aircraft, the track between the rows of seats is covered with an extruded rubber cap. There is actually a Boeing part number for this, but I do not know what it is, and it probably works only with the flanged and recessed track. Since this is going on the bottom of the window in my passenger van, I'd like to cover the stretches of angled track that aren't in use. Any solutions?
Sean
2006 Dodge T1N 158" Tall Roof Passenger Wagon w/Rear AC
seans is offline   Reply With Quote
Old 11-21-2011, 04:42 AM   #15
geoffs
2003 T1N 316CDI LWB
geoffs's Avatar
Still looking for an affordable L-Track solution and came across some aluminium extrusion similar to the 80/20 product but, in Australia at least, a lot cheaper. It's also available in the US.
Here's the specs:
At 16mm thick, it's a little thicker than LTrack. Cost for a 6metre length is $A124.
Geoff
The Following User Says Thank You to geoffs For This Useful Post:
owner (11-29-2011)
Old 11-29-2011, 04:27 AM   #16
owner
owner's Avatar
In Oz, this place has some L-track type extrusions...
Lots of connectors and joiners too.
Even has an online store, that particular profile above is $140 for 6 meters.
http://www.australiseng.com.au/prodd...LS.084.102.001
Old 11-29-2011, 06:21 AM   #17
geoffs
2003 T1N 316CDI LWB
geoffs's Avatar
There's also AME (locally made) but neither have a 16mm profile which I think would be the thickest you'd want for a tie down rail,
Geoff
Old 01-09-2012, 05:03 PM   #18
Strapman
Strapman's Avatar
Sean,
We currently sell a plastic filler strip that can be cut into sections that will snap into the unused sections of track. The roll is sold in 25' rolls here is the link http://www.cargoequipmentcorp.com/Wh...p/fe200751.htm
As for the end caps, our 8663 end cap (only one we stock) will work with the recessed Fe751 series track. http://www.cargoequipmentcorp.com/Se...ngs-p/8663.htm
The puck will not pair well with with any of the L track styles available. We have been looking into different style end caps but nothing set in stone as of yet.
Strapman is offline   Reply With Quote
The Following User Says Thank You to Strapman For This Useful Post:
seans (08-15-2013)
Old 08-14-2013, 04:07 AM   #19
Torchwater
Originally Posted by pdxh2o View Post
For all your Sprinter and other vehicle tie downs try : http://www.macscustomtiedowns.com/
I love this stuff and use it for everything cargo securing related !
Are their versatie tracks the same as L-tracks?
~Darin K~
2013 2500
Mercedes Crew Van 170in high roof
White stock color with black painted steel rims
Torchwater is offline   Reply With Quote
Old 05-18-2016, 11:17 PM   #20
RIDESprinter
Anyone still watching this thread? I want to put L-Track on the walls of my 2014 Sprinter 3500 Ext, but nobody seems to make an L-Track with the right dimensions.
This one from Rob's biz is almost right, but instead of a 1/2 inch rise up to the flange, I need about 1/8 of an inch maximum: http://www.cargoequipmentcorp.com/L-...51-100-pd4.htm (Need 1/8 so the flange will still squeeze and hold down the plastic wall pieces in place.)
Or, I could make something like this work, if it were 2 inches wide instead of only 1.25. - http://www.cargoequipmentcorp.com/L-...50-100-pd4.htm
Take my money, someone, please! Need to find the right track though.
RIDESprinter is offline   Reply With Quote
The Following User Says Thank You to RIDESprinter For This Useful Post:
jdemers90 (08-21-2017)
