Go Back   Sprinter-Forum > General Forums > Pictures & Videos
Pictures & Videos Sprinter Pictures & Videos
Old 05-25-2019, 04:24 PM   #1
turkeypie
Default 2000w inverter installation
Installed to the isolated battery connections beneath the swivel drivers seat. Home fabricated 6061 aluminum bracket attached to the existing holes using threaded inserts.
turkeypie is offline   Reply With Quote
Old 05-25-2019, 07:01 PM   #2
GSWatson
2013 144
GSWatson's Avatar
Default Re: 2000w inverter installation
What battery are you connected to? It sounds like youíre connecting to the EK1 connections under the driverís seat, which is only rated for 40 amps - that inverter can pull kite than twice that. And Iíd be afraid someone will look at that as a convenient step one day...
Cheers,
Greg
GSWatson is offline   Reply With Quote
Old 05-25-2019, 08:46 PM   #3
turkeypie
aux. battery tap relay, black 2 awg cable w/200A inline fuse.
Old 05-25-2019, 10:14 PM   #4
OrioN
2008 2500 170" EXT
OrioN's Avatar
Cheers,
Greg
The inverter will pull 200A @ 2000W, or 300A surge. This is too much for the auxiliary battery to handle.
