support Sprinter-Source.com
Click here or the banner before shopping at Amazon. A percentage of your purchase goes to support Sprinter-Source.com
Old 11-19-2017, 08:57 PM   #11
dun_roamin
Default Re: Power Window Fail
Here's what I ended up doing.
- 3d print the plastic part, 3d model found somewhere on this forum
- Bring the regulator to my garage, heat up 3d part until it stretched over existing rivet
- As part was a little malformed, use heat gun again on 3d part until it naturally fell back to its original shape
- Install regulator, use lots of grease, good as new!
Fingers crossed it lasts a few years.
Thanks for all your help!
dun_roamin is offline   Reply With Quote
Old 01-02-2018, 07:21 PM   #12
SondraRose
We bought the brass part off eBay mentioned in a previous post and used it very successfully!
We took the screws out of the regulator assembly and moved it slightly so we could get the slider into the window track, then screwed it back in. A ten minute job and $35. Yay!
SondraRose is offline   Reply With Quote
The Following User Says Thank You to SondraRose For This Useful Post:
OldWest (01-05-2018)
