Old 10-02-2017, 02:36 PM   #1
dun_roamin
Default Power Window Fail
Hi,
My driver side power window fell down into the door as I was opening/closing it. I removed the door panel and found that the control arm that moves it up and down had fallen off the rail attached to the bottom of the window. This was due to a plastic part that holds the control arm having broken.
Does anyone know where I can get that small white plastic part? People talk about using shower door rollers from home depot, but ideally I'd like to get the original part.
dun_roamin is offline   Reply With Quote
Old 10-02-2017, 03:55 PM   #2
Default Re: Power Window Fail
Welcome.
The Search function, although cumbersome and not always useful, shows several useful threads with various options for repair.
https://sprinter-source.com/forum/se...archid=3170651
Here are the more recent threads from that search, but you may also want to look at the older threads as well.
https://sprinter-source.com/forum/sh...+window+roller
1. Plastic part is apparently not available except as part of motor and rail assembly. Thus, the various cheaper shower roller or bolt/washers fixes.
2. A manual regulator designed without a plastic part may be cheaper but rivets need to be drilled out to be used. Fellow Westy owner Autocamp figured this out.
3. A power assembly replacement or a manual assembly replacement can be found at Europarts-Sd.com for much cheaper than Mercedes/Dodge.
4. Fellow Westy owner Autocamp posted details on his blog.
http://eat-drink-men-women.blogspot....indow.html?m=1
Please follow-up and post whatever you find and do. Thanks.
Old 10-02-2017, 05:56 PM   #3
onemanvan
I had the same problem - my solution probably looks a bit kludgey but it's been working fine for two years now. Less expensive than purchasing a new window regulator assembly. Some assembly required:-)
large nylon spacer 5/8" OD 1/8" thickness
small nylon spacer 3/8" OD 1/4" thickness
File Type: png Screenshot 2017-10-02 at 5.16.24 PM - Edited.png (61.5 KB, 159 views)
onemanvan is online now   Reply With Quote
The Following 6 Users Say Thank You to onemanvan For This Useful Post:
512Westy (10-02-2017), autostaretx (01-02-2018), irvingj (10-16-2017), Kiltym (10-03-2017), OldWest (10-02-2017), SondraRose (10-16-2017)
Old 10-02-2017, 10:43 PM   #4
Part numbers?
A. Track Rollers?
There are various things which look they might work. Maybe things called "cam followers and track rollers," but no one has apparently posted an exact part.
https://www.mscdirect.com/webapp/wcs...navid=12104104
From the various forum threads/posts, probably looking for:
Outer Diameter:
0.625" or 5/8" (about 16mm)
Inner Diameter:
Thickness of Wheel:
Attachment Bolt:
8-32 bolt, 1/2" long
(8 means diameter, 32 means threads)
B. Carriage Bolts or Mushroom Head Bolts
Posters have suggested using a carriage bolt. Autocamp suggested something similar. A mushroom head bolt may be a better fit as not as angular?
https://www.esmaxfasteners.com/c/513...in-603-brass-/
Old 10-06-2017, 01:25 PM   #5
Wasaabi
Sprinter Westfalia #133
Wasaabi's Avatar
I used the $4 shower door roller from Home Depot trick. I had to shave the roller plastic down to almost the metal. I tried various parts hoping to get to onemanvan's solution, but couldn't find the parts locally while rushing before our last trip. The shower door roller works well, although with all the plastic shaved off I don't have high confidence in longevity. At least I know how to fix it if it fails again.
Maybe before our big winter trip I will remember to stock up on the parts mentioned above just in case. Since this problem happens with no warning, and the plastic piece that breaks is now at a certain weakness with age on our Westies, keeping a set of the suggested parts on hand as spares is a good idea. FYI for those whose window falls into the door and need an emergency fix (eg, at night in cold rain), you can take the door panel off to retrieve the glass in about 5 minutes, then use tape over the frame to keep the window up in the track while awaiting the fix.
The Following User Says Thank You to Wasaabi For This Useful Post:
Old 10-06-2017, 03:52 PM   #6
Robert Foster
I made a simple single piece out of delrin plastic that has worked beautifully for two years. I actually made two of them and stuck the second one in my parts bin in case the passenger side fails. I will try to take a picture of it and post it this weekend.
2005 Sprinter Westfalia
Old 10-09-2017, 11:43 PM   #7
This Arizona company repairs power windows and also makes custom replacement parts. If someone does call them and finds out if they have a replacement part (see OneManVan's post with dimensions), please post. Thanks.
http://powerwindowrepair.com/
Old 10-16-2017, 04:51 PM   #8
SondraRose
Love it! Your post is just in time; our original failed after a camping trip on washboard roads.
Could you share your sources for the parts, please?
Oh, and a wave from Tucson! My parents live in Benson.
SondraRose is offline   Reply With Quote
Old 10-16-2017, 07:15 PM   #9
onemanvan
I found all the parts I needed at the local Ace Hardware store in Benson!
Old 10-16-2017, 07:34 PM   #10
A poster found a replacement part made in brass. The part looks like the rectangular plastic piece which breaks. The replacement brass piece is bolted on using the same type of bolt used by OneManVan. You will still need to cut and drillout the original rivet.
https://sprinter-source.com/forum/sh...2&postcount=42
[Quote:]
I didn't have the time to hunt down hardware and fabricate a fix for this, so I went for this overpriced but nice looking solution (still far cheaper than the dealer.) Got it on eBay, listed as "1995-2006 DODGE MERCEDES Sprinter window crank motor lift regulator repair kit", it's a brass piece manufactured in Estonia, post needs to be cut off and punched out of the arm, kit includes a replacement bolt and special nut. I hope it arrives soon. $34 with shipping.
[End Quote.]
Original link above has photos. Ebay link is below:
http://www.ebay.com/itm/1995-2006-DO...hZqv~j&vxp=mtr
Email to friendsShare on Facebook - opens in a new window or tabShare on Twitter - opens in a new window or tabShare on Pinterest - opens in a new window or tab | Add to watch list
Seller information
volvonest (8524 )
99.3% Positive feedback
Save this Seller
Contact seller
See other items
Item condition:New
Compatibility: See compatible vehicles
Quantity:
1
More than 10 available
18 sold / See feedback
Price:US $29.95 Buy It Now
Add to cart
3 watching Add to watch list
Add to collection
100% buyer satisfaction
30-day returns
New condition
