Old 11-19-2018, 03:46 AM   #1
tarpondale
Default outside temperature
our outside temp. gauge has always been off but now its way off, help?
tarpondale is offline   Reply With Quote
Old 11-19-2018, 07:44 AM   #2
Default Re: outside temperature
Presumably, you're talking about the dashboard temperature (the central computer console was not hooked up to a temp sensor but awhile ago there were posted instructions on how to connect one).
The Sprinter temp sensor snaps into a little hole in the front bumper chrome shiny plastic license plate at the bottom. Check to see if it's there or flopping around under the front bumper.
If temp reading is inaccurate before driving, the sensor might need to be replaced. If temp is inaccurate while driving (hotter or cooler???), is it properly located?
Apparently, defective temp readings cause engine running problems.
These are helpful threads:
https://sprinter-source.com/forum/sh...rature+reading
Be careful that folks are talking about the bumper ambient temperature sensor for dashboard and not other temp sensors like for the turbo air intake. Folks have apparently replaced (part # was listed in one post) or connector corrosion issues addressed.
Please post whatever you find or do. Thanks.
The Following 2 Users Say Thank You to OldWest For This Useful Post:
Mickyfin (11-19-2018), tarpondale (11-19-2018)
