Old 09-23-2018, 03:02 PM   #21
Robert Foster
Default Re: No turning back now
Originally Posted by Adolphus View Post
I notice Foster used a pair of unique beefy hinge brackets that look different from the oem hinge plates in parts catalog diagrams. Any ideas where these hinge brackets can be found?
I had the hinge bracket (the red primed piece in the thread) fabricated by a local welder for $125.
I was given some of the original OEM brackets that had been cut off another Sprinter with the intention of welding them back on to were our Westy ones had been cut off, but they were so wimpy, I didn't want to use them which is why I designed and had built the bracket assembly that I did.
2005 Sprinter Westfalia
Old 09-23-2018, 05:30 PM   #22
Adolphus
I’m interested in your hinge pieces that each have one bolt hole and the other ends go into the slots. Can you please tell me where I can get them?
Old 09-25-2018, 02:49 PM   #23
Robert Foster
Iím interested in your hinge pieces that each have one bolt hole and the other ends go into the slots. Can you please tell me where I can get them?
Those two hinges pieces came off of a junked Sprinter being parted out.
The Following User Says Thank You to Robert Foster For This Useful Post:
Adolphus (09-25-2018)
Old 09-26-2018, 01:22 AM   #24
Adolphus
I’ve decided to go with the original equipment Mopar part number 05104081AA which are less than three dollars each and allow adjustment up and down for different tire sizes when I add additional bolt holes.
Old 09-26-2018, 09:34 PM   #25
Adolphus
Thinking of securing the new Coleman ac from the underside of the installed 1/8 inch Aluminum plate directly with the supplied retainer bracket,This would prevent having create a new wood 14x14 inch frame other than whatís necessary to run ducting through original cabinet. It would also prevent having to grind down an edge of the retaining bracket. The picture of me holding up the retaining bracket against the temporary styrofoam is where the Al plate is to be secured by original kerstner bolts on top (a la Allcampís method). Any thoughts?
File Type: jpg 9FB60318-CEDB-44E0-9141-391373CE89AD.jpg (57.4 KB, 63 views)
File Type: jpg 9EA95454-CB07-4A0B-AB95-8CFEF36E494F.jpg (61.4 KB, 64 views)
File Type: jpg 5B502D60-63B6-443F-9410-79970C796E20.jpg (58.2 KB, 63 views)
Old 09-26-2018, 10:40 PM   #26
Not sure I follow.
1. Whatever you do, bolts are accessible from underneath?
2. How does weight support work?
The entire weight of AC is carried by aluminum plate, which is carried by top layer of fiberglass top?
Versus (true or not???) Weight of original air conditioner carried by top layer of fiberglass, wood frame carried by top layer and inner layer--then carried by bathroom wall??? (Don't know if the weight of original AC was carried how???)
Better example is the original bathroom roof vent. The vent was a clamp on so the weight of the vent was carried by both the top layer, wood frame, and inner ceiling layer---sandwiched together.
Old 09-26-2018, 11:41 PM   #27
Adolphus
Aluminum plate to be secured at six points defined by original bolts holding down prior kerstner ac. Will be using sikaflex 715 for sealing on top of preexisting flange now cut flush as per picture. Not sure how much sikaflex to use. The flange also sits on an existing sandwich of inner and outer ceiling shells with a small wood frame in between. The main difference with the bathroom vent is my big opening of about 25”x16”is being downsized to accommodate approx 14x14 opening (represented by two smaller openings at present for supply and return air which will feed from/to iriginal cabinet attached to bathroom wall above door. The 16x16 inch foam seal bears maybe half the weight on the aluminum spreading the load out to the bigger original opening. My concern is whether it would cause a drum effect as compared to putting in a wood frame and attaching the bracket below(using four long bolts in either option)
Old 09-27-2018, 01:00 AM   #28
If the two layers of the roof had been glued together with a polyurethane foam, it'd be like a SIP--Structurally Insulated Panel. The fiberglass roof would have been much stronger.
In lieu of a 14"x14" frame, could you use some spray foam in a can to fill in some of the empty volume areas so no drum effect? If you find the right kind of foam, might even add some strength. Lots of cautions re spray foam, including later unwanted expansion, VOCs, hassle to remove if later repairs, etc.
Also, just remembered TNeuer found their fiberglass roof around the skylight had sunken and added some support. But your big piece of aluminum would presumably do the same thing.
https://sprinter-source.com/forum/sh...ylight+support
Last edited by OldWest; 09-27-2018 at 01:05 AM. Reason: Add last paragraph re skylight.
Old 09-27-2018, 03:26 AM   #29
Adolphus
I like that idea. I can flush out the bottom side of the bracket with foam and then glue on thin plastic or wood base flush with the ceiling with clearance for airways. I’ll post a pic when I get to that stage. Need to find help to lift the ac onto the roof first. Should be a lot easier that my removal of the Kerstner (solo).
Old 09-27-2018, 06:03 PM   #30
onemanvan
I would strongly caution against the use of expanding foam in this application. Based on personal experience I believe it will cause the area around your opening to bulge outward. As a result your aluminum plate will no longer lay flat against the roof! There's really no way to predict or control how much bulging will occur. But one things for sure - it will bulge and it will do it very forcefully! Been there - done that:-)
Pnwsquid (10-17-2018)
