Old 05-02-2018, 03:51 AM   #1
Fredb
Default Trickle charge thru Lighter?
Do folks out there know whether you can trickle charge the engine battery by connecting through the lighter port.... am looking at a little solar powered trickle charger and trying to figure out whether I need an extension to connect directly to the battery or can go through the lighter port in the dash.
Thanks in advance for any help.
Fred
Fredb is offline   Reply With Quote
Old 05-02-2018, 08:10 AM   #2
Tooth Fairy
Away with the fairies.
Default Re: Trickle charge thru Lighter?
If the lighter outlet is live when the key is off and not going via the ignition then yes you can use it to charge.
Current ride
Previous vehicles.
Old 05-02-2018, 12:09 PM   #3
pfflyer
pfflyer's Avatar
The 12v outlet below the cup holders on a 2013 is always live and a plugged in Battery Tender to that outlet works like a charm.
The Following User Says Thank You to pfflyer For This Useful Post:
Bobnoxious (05-02-2018)
Old 05-02-2018, 04:19 PM   #4
Fredb
Thanks... got it. That makes sense. Will check when I get home tonite.
Old 05-02-2018, 04:41 PM   #5
Fredb
Old 05-02-2018, 04:55 PM   #6
CJPJ
2008 3500 170"ext. 3.0L
CJPJ's Avatar
For a long time I've had a little solar panel on the dash charging through the lighter port.
Old 05-04-2018, 05:08 AM   #7
Fredb
Ok... so now I have a different issue... the lighter port is 'dead'... seem to recall that it was working and then went bad a while back (as in, I plugged some device in and it shorted/blew).
Haven't dug into it yet, but am wondering if others have experience... is it on a fuse or are there other common issues folks have encountered?
Old 05-04-2018, 06:12 PM   #8
Yes, the cigarette lighter (in the ashtray) and the 12v power outlet (on the dash panel) each has a separate fuse.
The socket in the ashtray uses a 20 amp fuse in position #8 on panel 1 (under the steering wheel),
and the 12v outlet uses a 15 amp somewhere on the seat-side panel (location differs between Sprinters).
Note: although the ashtray fuse is larger, there have been a number of reports of that socket melting if run at high currents. The ashtray socket also feeds the radio and interior lights. The 12v outlet fuse is solely devoted to the socket.
CJPJ (05-04-2018)
Old 05-05-2018, 04:24 AM   #9
Fredb
Dick,
Thank you very much for the detailed information... would have taken me awhile to figure out the location of the fuse without your help. Really appreciate it.
-Fred
Old 11-24-2018, 02:39 PM   #10
wwjase
Hello, and thank you. Could you please offer a few more details? I'm asking because I found solar power trickle charger by Suaoki (I have liked other products from them). It's an 18w panel, but more curiously, it recommends to unplug it at night in case it fails and begins to draw off the battery rather than recharge. That of course is not convenient. Additional research tells me people have added a controller to circumvent that potential problem.
Questions 1) what panel size has been successful for you, and 2) does yours have its own controller and/or did you add one?
Thank you kindly.
wwjase is offline   Reply With Quote
