Old 11-24-2018, 03:44 PM   #11
Adolphus
Default Re: Mini toad for Westy
The brake harness plug’s spring clip is at the bottom at the back of the brake sensor connector (which is above the brake pedal). Easy to disengage from the connector if you gently push up the plastic spring clip as you slide the plug out. This makes it easier to access the wire identified by autocamp to tap into...once I practice soldering skills and define correct wire gage to graft in.
I’m not an electrical guy, but I’m thinking it can be accomplished by using a fuse tap at the brake light fuse which is under the steering column (fuse 5). I'm apprehensive about messing with the wire at the braking sensor...one slip and wiring is toast.
In this picture I’m pushing in the clip spring with my thumb (couldn’t get Movie clip to post)
File Type: jpg 38FBAEAD-1AE0-46DF-8F44-13F517EB2570.jpg (61.1 KB, 17 views)
