Old 02-15-2014, 02:13 AM   #1
ecobon
Default Remote Control Damaged - How to Open Sky Light Window?
I am unsure if my remote control is working--the batteries are fine and I checked to make sure that the polarity was correct as per markings on the inside of the remote.
If I cannot get the remote operational, how can I operate the window? Would a universal remote work if it was programmed by another Westy owner?
ecobon is offline   Reply With Quote
Old 02-15-2014, 02:50 PM   #2
OrioN
2008 2500 170" EXT
OrioN's Avatar
Default
Have you checked the fuse for window?
Sent from my GT-I9100M using Tapatalk
Old 02-15-2014, 03:00 PM   #3
Old Crows
Calypso 2014 View Profile
Old Crows's Avatar
Default Re: Remote Control Damaged - How to Open Sky Light Window?
As a Master of the Obvious..... The Crow asks ...... "Ya really sure ya got the batteries inserted the right way!" Eh!?
Is the sky light locked? Jammed? Frozen shut?
Old 02-17-2014, 11:37 AM   #4
discus
GA Westy
Default
I will test the universal remote and let you know.
Old 02-17-2014, 12:00 PM   #5
grozier
A good tip seen earlier on this or the Yahoo board for testing remotes is to point it at a smartphone or digital camera and film it while pressing buttons.
For IR devices like these, the camera can see the light. For RF devices, it will not work.
There are instructions in the Westfalia supplement on how to use the emergency crank if needed.
Ted
Old 02-17-2014, 03:59 PM   #6
discus
GA Westy
I tried programming my Harmony 880 remote and it does accept the code but for some reason, the unit freezes on the down button. A single tap on the up button works fine and the skylight goes all the way up. I have to experiment some more later and also try a more conventional learning remote.
Old 02-18-2014, 02:26 PM   #7
onemanvan
On the Yahoo forum a member attempted to reprogram a remote. He had the same problem with the down function. Apparently there is no work around for this issue. Some decided to install a manual switch. One of them contributed a detailed document describing the procedure. I attempted to attach it to this msg. In case that doesn't work here is a link:
https://f1.grp.yahoofs.com/v2/1HoDU0...2Brecovery.pdf
Old 02-19-2014, 09:32 AM   #8
discus
GA Westy
Default
The harmony remote issues a one second signal. So it does not work for the down button. The raw learn can handle long sequences, I was planning on Using buttons 1 to 9 to program a series of down button events of varying lengths with 9 long enough to close it completely. I will try that. I have also emailed harmony about making the down button work more like volume buttons but no response yet.
Old 02-19-2014, 12:06 PM   #9
skydiver007
DRB III Owner If You Need
I program thousands of remotes. Here is what you do. Create a device in the harmony remote and simply learn the down button to the volume button which is a constant out while you hold it down. That should do it.
You could also get a simple universal remote at Walmart for $8 that has learning capability and simply learn the down to the volume button.
skydiver007 is offline   Reply With Quote
The Following 2 Users Say Thank You to skydiver007 For This Useful Post:
discus (02-19-2014), Old Crows (02-19-2014)
Old 02-19-2014, 01:23 PM   #10
discus
GA Westy
I guess I haven't tried that. I did try using an old SIMA SUR-20 remote and it works just fine.
