Old 05-12-2012, 03:14 AM   #1
Aqua Puttana
Poly - Thread Finder
Aqua Puttana's Avatar
Default Fuel Tank Coil Rusty Wye Fittings
BEWARE
The fittings supplied by Dodge and MB may not be correct. Check for proper parts before ordering.
Thanks to theordore for the info.
Post #26
Originally Posted by Theodore View Post
I realize I'm late to the party, but this part starting gushing fuel (Attachment 103031)
last week on my T1N and I found this post. Ordered Dodge # 05133920AA. It showed up today, so I pulled the original damaged part (Attachment 103032)
and was disappointed to discover that it's not going to fit. The replacement is a 1/4" fitting, but the original is 3/8" if not larger (Attachment 103034).
There also very different in shape (Attachment 103033).
The replacement is definitely not flexible enough to accommodate the difference in angle.
I thought you'd like to see this so you don't count on a part that's going to leave you stranded when the original gives up.
The question is: where do we get an actual replacement part? I waited 9 days for this worthless thing.
So I've been carrying around a part that won't fit?!?!?!?
Damn!
Sorry for any misinformation about parts, but it's what I was supplied from the Dodge dealership.
One of the reasons that I have yet to replace the 2004 crusty looking fittings was that the access and parts change looked to be a bit of a pain.
One answer to the problem is to use 3 ea. long(er) hoses and route the fuel hose out to a traditional Tee fitting. Alternatively, it looks like either a Wye or Tee fitting should install on 2 legs with no problem. A long hose loop can be used for the leg that doesn't align properly.
Added:
If OEM isn't possible, and the long hose loop method is necessary, 3/8" barb Tee fitting are more common locally than are Wye fittings.
Additional reflection:
It may make sense to install an equal leg Y fitting in a backwards facing orientation. That should allow the loop hose to fit into the space available and maybe use less hose.
JB Weld will seal the hole shown center in the picture [in other thread], and the other hole in progress up by the white dot.
Please let us know if the removed part is 5/16"... 3/8" or some other SAE equivalent size.
Anyone want to buy some brand new, unused OEM packaged dealership fuel parts for their T1N Sprinter?
If it is 5/16" (Reported to be 3/8", but 5/16" still might work.)
https://www.amazon.com/Saim-Brass-Ba.../dp/B01LYZ81BC
https://www.amazon.com/Stainless-Ste.../dp/B076PVN18X
3/8"
https://www.amazon.com/Uxcell-a15042.../dp/B00YX8WAV2
Jegs carries some parts.
https://www.jegs.com/i/NOS/741/15534/10002/-1
Every Jegs web page contains this note. Be aware.
"Some parts are not legal for use in California or other states with similar laws / regulations"
This picture shows the possible alignment for 2 ea. legs.
The original text/thread starts here:
Today while I was working under my Sprinter (wheels blocked, with jackstands and floor jack in place) I noticed some rusty fitting parts on the fuel cooling loops. I did some searching because I thought I've seen some parts diagrams of the fuel tank, but these weren't included. They look pretty nasty so I want to replace them before failure.
I suspect they are check valves. - Edit: Only because they appear to be larger than a regular fitting. - That is a guess. [That guess was wrong. They are Wye fittings. Refer to post #11.] Anybody know what they are for sure? Part number would be appreciated (again, post #11). Probably worth inspecting if your Sprinter lives in the salty Northeast like mine does. On a happy note, my fuel cap still looks pretty good. vic
Old 05-12-2012, 07:36 PM   #2
bc339
Default Re: Rusty Fuel Coil Fittings
Vic, see if this is of any help. 7 is called a change over valve, 56 is called a distributor only with the aux heater. 52 are plastic pipes only with aux heaters.
I'll keep looking...
Bruce
2004 US T1N 158" 2500 Passenger, High roof, Rear Air, 2.7L, - the "Crew Bus"
bc339 is offline   Reply With Quote
Old 05-12-2012, 09:09 PM   #3
Aqua Puttana
Bruce,
Thanks for the research. Actually the diagram you show looks a bit different from mine.
I found this diagram in the 2006-VA PDF manual page 1003. It looks like mine. The diagram seems to show three lines (hoses) going to my rusted fittings. I'm afraid to even touch them because they look so ugly. Unfortunately my info doesn't specify the parts I'm looking for. Monday I'm going to stop by the dealership and talk to Chet the parts guy. I'm hopeful we can find the proper part number. Thanks for your efforts and reply. vic
Bruce
Old 05-12-2012, 10:45 PM   #4
autostaretx's Avatar
Are they both "Y" fittings?
Coupling a single pipe from the thermostat into two pipes going into the coils?
Vic's diagram suggests that.
Old 05-12-2012, 10:56 PM   #5
bc339
Can you check the rusty parts to see if they "Y"? Both Dodge and MB EPC (and your manual) may suggest that the rusty parts are p/n 56.
Bruce
Old 05-12-2012, 11:20 PM   #6
Aqua Puttana
Good point. I hope you are correct in that they are simple fittings.
Bruce
I didn't interpret #56 as being a similar "Y". I just saw the differences in the diagrams. I'll crawl under and check closer tomorrow.
When I establish exactly what they are I'll be certain to follow up here with part numbers and info. Thanks for the continued interest.
angolaron (05-13-2012)
Old 05-13-2012, 04:43 PM   #7
Aqua Puttana
Bruce
Bruce,
A second look shows that they are "Y" fittings. Most likely they were plated steel at one time. They are rusty clumps now. That is probably why my fuel cap still looks OK. Maybe these parts acted as sacrificial anodes??
I'll mention "distributor or distribution" fitting to the parts guy. Thanks. vic
Old 05-14-2012, 02:50 AM   #8
bc339
Here's the Dodge p/n for the Y - 05133920AA
Bruce
The Following User Says Thank You to bc339 For This Useful Post:
Aqua Puttana (05-14-2012)
Old 05-14-2012, 01:49 PM   #9
talkinghorse43
Being that they're Y fittings, they're likely to be cast parts and thick wall. IIWM, I'd chip off the rust and coat with Rustoleum's rusty metal primer rather than replace straightaway.
'02 316 2500 SHC FTL 140 passenger, NAG1, 3.73 diff, 16" wheels, OM612 w/EGR (>415k mi.), '04 Golf PD-TDI (>160k mi.), both bought new
talkinghorse43 is offline   Reply With Quote
Old 05-14-2012, 03:25 PM   #10
Aqua Puttana
Gee TH43,
Even though we've never met I consider you a friend based upon forum interactions. That said, as a friend you really shouldn't enable my cheap tendencies. I'm tempted to just repair, but I ordered the parts this morning. Those fittings really look bad. I'm even thinking I may just cut and replace all the short hoses to minimize risk of damage to the plastic lines during disassembly. I'm pretty sure damaging those plastic hose coil assemblies would add a bunch of cost to the project.
Thanks for the input. vic
P.S. - Bruce's part numbers were exactly correct. Just drop the zero.
P.P.S. - I even ordered 2 ea dashboard switch cover blanks. I'm throwing money around like a drunken sailor.
