Old 09-21-2018, 05:37 PM   #1
Kiltym
Default Tilting back seat mod issue
We removed the 6 bolts on the back seat to allow the seat to fold forward. All works as expected, and certainly allows for much easier access for storage.
The question is the two bottom corners of the fabric, where they lay until the metal brackets, rub every time the seat is folded and put back, resulting in the fabric starting to wear through. I temporarily put some strong tape over the two spots, but wondering if others have the same issue, and have come in with a good solution, for this issue.
Old 09-23-2018, 02:51 AM   #2
CaptnALinTiverton
CaptnALinTiverton's Avatar
Default Re: Tilting back seat mod issue
Not an issue for me; there is enough slack in my fabric so there is little wear.
AL
Old 09-26-2018, 03:56 AM   #3
Kiltym
Here is a photo of the damage happening. The fabric rubs against the bracket when tilted forward or back.
If others do not have this same issue, perhaps there is a slight tolerance difference in our bench.
We reinstalled the bolts. Too bad.
Old 09-26-2018, 06:41 AM   #4
Have not personally used, but search for things like "furniture defender" for cats on Amazon. Here's a website on protecting corners of upholstered furniture.
http://www.upholsteryresource.com/node/279
Old 09-26-2018, 03:07 PM   #5
onemanvan
Mine does the same thing - IE: binding and gradually cutting through the fabric...
