Old 10-10-2018, 09:30 PM   #41
Riptide
Riptide's Avatar
Default Re: No turning back now
Nice writeup. At some point, I plan to also put in this unit...
Is this model plumbed in to your freshwater supply, or do you fill the water reservoir separately? (From the pictures, it looks like the latter option...)
Old 10-10-2018, 11:26 PM   #42
Adolphus
The Thetford c402c cassette toilet model I bought has a built in separate reservoir which is filled independently from the main fresh water tank. I could have plumbed it from the main tank, but prefer it separate.
Old 10-13-2018, 01:41 PM   #43
Adolphus
Bathroom complete and feels roomier. Shower pressure is just a drizzle, but adequate. Iím looking for a less yellow light and also plan on treating the sink bowl chemically to bring back the original white. Iím pleased with the increased toilet seat height with the added 1.5Ē base.
File Type: jpg 24FC9433-8B23-492A-8424-0E10CB3632DC.jpg (89.5 KB, 75 views)
File Type: jpg D99909D7-F653-4C8E-9679-B8D5403F73C7.jpg (64.1 KB, 76 views)
Old 10-15-2018, 10:22 AM   #44
Riptide
Riptide's Avatar
Looks great! The way Westfalia intended.
Old 10-16-2018, 01:31 AM   #45
Adolphus
Thanks! Iíve located a set of shower heads that hopefully will provide a stronger stream (less nozzles and maybe less internal restriction) from iboats.com: Scandvik part number IB00288989
Old 10-17-2018, 06:01 PM   #46
Pnwsquid
Thank you so much for taking to time to share this. I'd argue one of the most consistent problems westy owners deal with are the A/C and Between the Eat,drink,men,woman blog (unbelievable information as well) and your post, it seems like the solution is becoming more streamline.
FYI, here is a picture of my Generator relocation method. I used a standard driver side spare tire carrier, upside down, cut the door side mounting bracket and welded a new one on to clear the door handle. The box is just a reinforced aluminum box, with boat hull covers to allow for ventilation intake and a 500CFM 110v fan for cooling. You would be blown away at how quiet this setup is. Hard wired into the input from the previous Onan genset.
If you use an easy start module a honda eu 2200i (new version of eu200) should easily be able to power a 13.5k or 15k btu AC. (https://www.microair.net/collections...nt=30176048267)
Old 10-17-2018, 06:09 PM   #47
Pnwsquid
I fitted a more powerful water pump that made a huge difference in pressure. the GPM might be higher, but we find we use the same amount of water as it doesn't take as long to "de-soap".
Old 10-17-2018, 06:20 PM   #48
Pnwsquid
The video doesn't do it justice, but the generator is essentially inaudible at about 100 feet. Especially if you are in the woods.
https://drive.google.com/file/d/1mck...ew?usp=sharing
Old 10-17-2018, 10:15 PM   #49
Adolphus
Thanks! Can you provide info on the water pump you chose? I tried to access your google links but the site says I need special permission.
Old 10-18-2018, 03:58 AM   #50
Pnwsquid
Should work now.
Here is the pump I used: http://a.co/d/26fJ2zF
The inlet hose from the van water system actually fits inside the pump output, miraculously, rather that over the outlet like the original pump.
The Following 2 Users Say Thank You to Pnwsquid For This Useful Post:
Adolphus (10-18-2018), Mr1987joker (10-19-2018)
