Old 08-17-2018, 04:50 PM   #11
Old Crows
Calypso 2014 View Profile
Old Crows's Avatar
Default Re: Wallowing...
Ok. You made two changes.
New tires. Same brand and design as the old Michelins. Right? Using the same pressures. ?
The other change is the alignment.
Frankly, if themtires and the pressures are the same as the old ones and the RV handled OK, you really need to examine the alignment. Its the only thing you have done that will affect handling.
Unless.....the replacement tires do not have the exact construction and capability as the old ones.
Old 08-17-2018, 05:13 PM   #12
Bobnoxious
Bobnoxious's Avatar
How much does your vehicle weigh and loaded???
"An ounce of prevention is worth a pound of cure"ó
Benjamin Franklin
"The bitterness of poor quality lingers long after the sweetness of the low price is forgotten" ó Benjamin Franklin
"Tell me and I forget. Teach me and I remember. Involve me and I learn"ó Benjamin Franklin
Sprinter information
http://diysprinter.co.uk/reference/
20O7 Service Manual
http://diysprinter.co.uk/reference/2...nformation.pdf
Old 08-21-2018, 10:53 PM   #13
Fredb
Thanks to all for the input and suggestions. I added a 5 lbs front and rear and seems to have helped... perhaps improvement is also a function of new tires finally settling in.
Regarding the rear sway bar, wverything looks fully intact to me... did a pretty thorough inspection.
Regarding wheel mounting I confirmed that the correct length bolts were used and that everything is snug.
Regarding shocks I have the red Koniís plus foam bumpers (am forgetting the name right now). They were set to the medium compression setting and so could probably benefit from an adjustment to increase the dampening.
The last point raises another question Iíll put out to the group... weíre on a swing through the northwest (currently at Lake Louise) and will be making our return to SF thru southern Oregon. Iím thinking to get the van serviced as we make our way through that area (where I know is a haven for Sprinter RV suppliers and aftermarket shops) and am curious whether folks have a mechanic/shop they recommend. Am thinking to get a standard service and get the wheels/suspension checked out/adjusted (and maybe get a new set of tires for the front). Thoughts recommendations would be welcome/appreciated
Fredb is offline   Reply With Quote
Old 08-21-2018, 11:14 PM   #14
If going through the Seattle, Washington, area, there is an Airsteam Westfalia owner and Sprinter mechanic who has worked on several Westies.
https://sprinter-source.com/forum/sh...Chang+mechanic
https://sprinter-source.com/forum/sh...7&postcount=13
The widely known contributing UpscaleAuto/SprinterStore in Portland, Oregon, is often recommended BUT there is a small quiet undercurrent of mixed reviews among Westy owners (as well as other Sprinter owners). While the company has changed hands in the last couple of years, do not know if these issues have been resolved.
There is an outfit in southern Oregon which focuses on suspension and handling. Do not know if any Westy owner has paid for their evaluation but it'd be interesting.
https://www.hendersonslineup.com/motorhome-rpa
https://www.hendersonslineup.com/coupons
Old 08-21-2018, 11:56 PM   #15
Pnwsquid
Originally Posted by Fredb View Post
Tire pressures at good both front and rear... thatís not the issue.
Sounds like it is the issue.
Old 08-22-2018, 09:30 PM   #16
Fredb
Oldwest... any contact info for Michael Chang... checked both threads and didn’t see anything and did a google maps search yield anything either
Old 08-22-2018, 10:51 PM   #17
Somebody may have better info. Last info I had was:
Mike Chang
Ravenna Ave NE
Northern Seattle.
Think his home number is
206 Ignore 227 Ignore 7870 Ignore
https://sprinter-source.com/forum/sh...7&postcount=16
Old 10-11-2018, 11:32 PM   #18
Fredb
Belated return to this thread...
Sooooo, after trying tire pressure and getting the bushings/rear anti-sway bar inspected and putting a new set of tires on the front to go with the rear, I had the folks at SprinterStore in Tualatin (south of Portland) adjust the compression setting on the Koni shocks. Somehow they were set to only 10% compression by original installer. They bumped the compression setting to 70%. With that change, the handling noticeably improved. That said, I'm still not clear on how it went from good to bad following the initial tire change and so that will remain a mystery. Additionally, I 'sprang' (pun intended) for the 'spring assist' kit that the SprinterStore folks sell (they're on sale right now!) to further strengthen/stabilize the back end. I haven't actually driven it yet (something to do with running square into a deer on the way to the Oregon coast), but am confident that it will only make the handling better, particularly as I'm fond of carrying a motorcycle on the back end of my Westy.
Old 10-12-2018, 01:34 AM   #19
Riptide
Riptide's Avatar
10%??? That would definitely do it. It seems most Westy users that install the Koni's have them dialed up closer to 100%, since we're so close to the GVWR as it is...
Old 10-12-2018, 04:57 PM   #20
Fredb
What I'm still confused by though is that it handled great before the tire change and can't believe that the folks who changed the tires made any adjustment to = the shocks. Guess that will have to remain a mystery.
Am excited to see what effect the 'spring assist' has. Will report back once I get to drive it.
Again... FWIW, for those who might be interested, the SprinterStore has a pretty significant discount on the spring assist right now https://www.sprinterstore.com/produc...st-suspension/
