Old 01-05-2016, 03:42 AM   #11
avanti
2014 GWV Legend 3500 I4
avanti's Avatar
Default Re: Espar D4 High Altitude Pump
Originally Posted by GoJohnGo View Post
Seeing that the High Altitude Compensator is wired between the Heater Control Unit and the pump, my guess is that the Compensator is only modifying the duration of the pulse, not the frequency.
Just the opposite, I think. At least it isn't true as it modulates on startup:
http://sprinter-source.com/forum/showthread.php?t=9070
I am pretty sure that these dosing pumps are solenoid/diaphragm type. If so, they are insensitive to pulse width. That is why they are so precise.
--Pete
The Following User Says Thank You to avanti For This Useful Post:
vanski (01-05-2016)
Old 01-05-2016, 04:13 AM   #12
vanski
'05 Box Snow Camper
vanski's Avatar
How did I not see this post! This is going to be much easier than I thought. Just need the time between all my different projects..
And yes, a pacemaker isn't too far off but it would be an almost certain death sentence
Old 09-27-2018, 10:02 PM   #13
TROLL
2007 Winnebago View 23H
Hey vanski -- did you ever make headway with this project? Sorry for bumping all the Espar high altitude threads, but love all the ideas floating around and curious what has risen to the surface in 2018 :).
TROLL is offline   Reply With Quote
Old 09-30-2018, 04:29 AM   #14
CaptnALinTiverton
CaptnALinTiverton's Avatar
I did extensive forum research years ago and conclusion was that just putting the HI-ALT pump in parallel (with e-switch) was the best solution. So I purchased the kit parts and all works fine but it was a hand-buster fitting those fuel lines together. In retrospect, since I don't travel in very cold weather, I should have just changed the pump.
AL
