Sprinter Rep / Utah
test
Josh Stepanski Mercedes-Benz of Draper, UT MB/Sprinter Rep Joshua.stepanski@lhmauto.com |
#2 |
Sprinter Rep / Utah
test
#3 |
Sprinter Rep / Utah
dsuplicate not
#4 |
Both versions did appear to work, including Avatar image.
![]() --dick
2005 T1N 118" Freightliner 2500 Passenger Wagon (2.7L, 15" tires, standard (short) roof) Get YOUR Sprinter's full configuration datacard by entering your VIN to https://www.datamb.com/ http://diysprinter.co.uk/reference <-- lots of service documentation, Thanks to Jens Moller and Arnie_Oli ((as always: this post may go through a couple of post-posting edits... so maybe give it ten minutes before commenting)) |
#5 |
Hello new to Forum. I've browsed others posts but this is my first post. Aloha, Josh.
2006 Dodge Sprinter TIN 173,000 miles Honolulu, Hawaii |
#6 |
Hello new to Forum. I've browsed others posts but this is my first post. I have a problem with a leaking seal on the transmission side where the drive shaft connects. I read a few other posts about the seal replacement on the rear differential and started to investigate the leak. I removed the driveshaft and got to the nut that needs to be removed. There is some kind of locator pin or dowel that is in the way of taking the nut off. I'm not sure how to remove it, all the information that I have found doesn't describe it or list the part. I'll include pictures. Sorry if they are not the best I don't have good clearance to get better pics. Lmk what you think.
Aloha, Josh. 2006 Dodge Sprinter TIN 173,000 miles Honolulu, Hawaii |
#7 |
#8 |
#9 |
Hi Josh, you may get better results posting here.
https://sprinter-source.com/forum/fo...play.php?f=106 |
Thread Tools | |
Display Modes | |
