Old 12-02-2016, 05:08 AM   #1
caseylentz
caseylentz's Avatar
Arrow Looking to buy sprinter van but need your help !
Hi,
I'm new here to the forum and this is my first post. I'm looking at purchasing a sprinter van for commuting back and forth to work and occasional overnights and road trips. I'm looking on craigslist for used vans in the San Diego area. I've been looking around the forum and getting a lot of helpful information and questions to ask sellers. I found this van http://sandiego.craigslist.org/nsd/cto/5864356835.html , the add says it needs a new Head Gasket. Any idea as to how much this might be to replace ?
caseylentz is offline   Reply With Quote
Old 12-02-2016, 05:15 AM   #2
BenJohnson
2006 2500 T1N
Default Re: Looking to buy sprinter van but need your help !
I like the phrase in the ad: "Con: needs head gasket. Motor runs and sounds great" - yeah right.
So, the SELLER says it needs a head gasket. How did it get that way? What else is going on? 236k miles - might be a lot.
$6750? not a chance. $2k maybe. I'd walk away, unless I was into a project.
BenJohnson is offline   Reply With Quote
The Following User Says Thank You to BenJohnson For This Useful Post:
caseylentz (12-02-2016)
Old 12-02-2016, 05:18 AM   #3
caseylentz
caseylentz's Avatar
Ben, I'm not sure what's going on with it. I'll follow up with you once i hear back from the seller.
Old 12-02-2016, 05:36 AM   #4
MikeP
First, I am not in anyway knowledgeable in repairs of any sort.
My frist worry would be runs great but needs head gasket. Small leak? Thinks leaking from head or just gasket? Whom diagonsed that it needs head gasket?
As many others here have pointed out before, is there any stored codes? Are theire anyone in area or shop in your area with professional scan/diagnosis problems?
Half done remodels? Safe? Leaks? Mounting points sealed?
I'd take a high pressure wash and be sure spray great deal underneath van and around all windows.
IMHO: High miles for that price! Our 03 Passenger 140" WB SHR model has less than 54K miles have been told only worth $5K.
"Good Luck!"
2003 140SHR 2500 Passenger Model
MikeP is offline   Reply With Quote
The Following User Says Thank You to MikeP For This Useful Post:
Old 12-02-2016, 07:31 AM   #5
outbound
06/2500/140
very seldom is the head gasket the only thing bad in situations like this.
would guess that overheating may have been involved in that gasket failing (since it''s pretty rare for them to just up and fail otherwise)
in that case, the head itself could also be a problem (warped, cracked etc)
unless you feel confident about doing the job yourself - or have someone you trust willing to help, if not just do it for you,
i would stay away - or bargain harder with the seller - as there's simply too many ?'s on something like this, to pay more than salvage value.
IF the body was cherry tho, like NO rust and everything else was looking good?
then taking a chance MIGHT be in order, assuming your're prepared for the wor$t...
just 2 more cents.
outbound is offline   Reply With Quote
The Following User Says Thank You to outbound For This Useful Post:
DesertAdventures (12-02-2016)
Old 12-02-2016, 07:57 AM   #6
obie
'04 long & tall passenger
"Good Luck!"
I don't know of any Sprinter that runs that is only worth 5k. Don't trust whoever told you that.
obie is offline   Reply With Quote
Old 12-02-2016, 11:02 AM   #7
Eric Experience
Eric Experience's Avatar
casylents.
Hitting a Sprinter with a high pressure washer will reduce its value to about $5K. about six weeks ago someone in England rote of a Sprinter with a High pressure washer. There should be an icon under the bonnet sorry hood showing a hose with a led slash across it. Eric.
Eric Experience is offline   Reply With Quote
Old 12-02-2016, 11:52 AM   #8
obie
Mine has that!
Old 12-02-2016, 04:30 PM   #9
glasseye
glasseye's Avatar
Originally Posted by obie View Post
Mine has that!
Mine, too. Exactly as described. NAFTA 04
"Frito" : the potato chip truck. 04 Hi-Roof 140 cargo.9800 miles by PO
150K miles in 10 summers. Fuel, filters, oil, tires, bulbs, batteries, front brakes, serp belt and tensioner, upper charge air hose, Cyl 3 failing GP.
Accompanied and assisted by "Cheeto", a 2019 Rad Powerbikes Rad City Stepthrough.
"Travels With Frito" Global travels by van, motorcycle and other www.petercmclennan.com
Absent this forum, I'd never have bought a Sprinter.
glasseye is offline   Reply With Quote
Old 12-02-2016, 05:10 PM   #10
surlyoldbill
surlyoldbill's Avatar
WOW! A Sprinter with only 236k miles for only $6750 in California?! That sounds like a bargain too good to be true, so have a pre-purchase inspection done by a shop. They are around $200, but worth it if you have doubts. I recently sold my 280k van for $12.5k, which was very reasonable for California. If you want a low mileage van, there is a 2005 in the SF Bay Area with only 20k miles for $25k.
Former owner of Surly Mobile:
2003 140shc 2500 passenger model, now owner of Transit T250 148MR 3.7
mobile design office, cargo hauler, family shuttle, action adventure base
surlyoldbill is offline   Reply With Quote
Tags
advice, t1n
