Go Back   Sprinter-Forum > Miscellaneous > Test Area
Test Area Place to develop your Forum skills.
Old 08-16-2019, 07:39 AM   #1
mercedes-josh
Sprinter Rep / Utah
mercedes-josh's Avatar
Default test
test
Josh Stepanski
Mercedes-Benz of Draper, UT
MB/Sprinter Rep
Joshua.stepanski@lhmauto.com
mercedes-josh is offline   Reply With Quote
Old 08-16-2019, 07:40 AM   #2
mercedes-josh
Sprinter Rep / Utah
Default Re: test
test
Josh Stepanski
MB/Sprinter Rep
Old 08-16-2019, 07:42 AM   #3
mercedes-josh
Sprinter Rep / Utah
Default Re: test
dsuplicate not
Josh Stepanski
MB/Sprinter Rep
Old 08-16-2019, 06:22 PM   #4
autostaretx's Avatar
Default Re: test
Originally Posted by mercedes-josh View Post
test
Both versions did appear to work, including Avatar image.
Old 08-26-2019, 07:40 PM   #5
Procycle
Default Re: test
Hello new to Forum. I've browsed others posts but this is my first post. Aloha, Josh.
2006 Dodge Sprinter TIN
173,000 miles
Honolulu, Hawaii
Procycle is offline   Reply With Quote
Old 08-26-2019, 07:48 PM   #6
Procycle
Default Re: test
Hello new to Forum. I've browsed others posts but this is my first post. I have a problem with a leaking seal on the transmission side where the drive shaft connects. I read a few other posts about the seal replacement on the rear differential and started to investigate the leak. I removed the driveshaft and got to the nut that needs to be removed. There is some kind of locator pin or dowel that is in the way of taking the nut off. I'm not sure how to remove it, all the information that I have found doesn't describe it or list the part. I'll include pictures. Sorry if they are not the best I don't have good clearance to get better pics. Lmk what you think.
Aloha, Josh.
173,000 miles
Honolulu, Hawaii
Old 08-26-2019, 08:40 PM   #7
Procycle
Default Re: test
Old 08-26-2019, 08:41 PM   #8
Procycle
Default Re: test
Old 08-26-2019, 08:45 PM   #9
Bobnoxious
Bobnoxious's Avatar
Default Re: test
Hi Josh, you may get better results posting here.
https://sprinter-source.com/forum/fo...play.php?f=106
