Old 05-21-2019, 12:05 AM   #1
white whale
white whale's Avatar
Default side mirror surgery
Decide at the last minute to see if anything is harvestable before tossing. My convex had gone a while back and the big one had some chips along the edge.
If you want to remove yours....
push in bottom all the way in
flatblade or pry tool to push up, hand pull the rest of the way.
Turns out the reverse is also a mirror, Have not figured out show to separate yet. There is a hole
in the plastic frame that shows the mirror surface.
I doubt a glass shop would cut a shape like this, cheaply.
Will post again if I get the reverse side out, will be a pristine mirror at least.
Assume this was done to be cost effective with the supplier and install - universal fir for either side.
Ok, win for this part.
OM647 2500 Dodge cargo
2006 158 WB Super High Top
375K km Outfitting for Baja Mx adventure
white whale is offline   Reply With Quote
Old 05-21-2019, 02:20 AM   #2
autostaretx's Avatar
Default Re: side mirror surgery
Any semi-competent stained glass hobbyist/artist or shop should be able to cut it ... (heck, my wife could (i'd wobble a bit))
... you just need to appear with a sheet of the correct thickness mirror stock (or call, a shop may have it).
A few years ago there was a company that supplied many shapes and sizes to auto parts stores.
I bought one that was "close enough" to replace a missing mirror on my father-in-law's car.
(there may have even been a thread here about 8 years ago on hunting down 3rd party replacement mirrors)
The double-sided may be a weather-protection method for the silvered reflective surface.
I don't recall my mirror being double-sided when i had it out once.
(the backside was the heating pad)
Old 05-21-2019, 08:34 AM   #3
Cheyenne
UK 2004 T1N 313CDi
Cheyenne's Avatar
Instead of using tools and risking chipping or breaking the mirror (in case you want to re-use it) push the TOP of the mirror all the way in then push the bottom of the glass UP with your fingers and slide the glass up around a quarter of an inch to unlatch it, then push the bottom fully in and remove the glass from the top.
This was the MB procedure in the instructions for fitting the top parabolic mirrors.
Keith.
36,000 miles from New
The Following 2 Users Say Thank You to Cheyenne For This Useful Post:
Aqua Puttana (05-21-2019), Midwestdrifter (05-26-2019)
Old 05-21-2019, 04:34 PM   #4
Aqua Puttana
Poly - Thread Finder
Aqua Puttana's Avatar
Judicious use of a heat gun might help remove the mirror glass without damage.
