SubForums: Events Scanners
Old 03-07-2019, 07:22 PM   #11
autostaretx's Avatar
Default Re: Backup alarm toggle switch
I would hope ("it wishes were horses") that the Sprinter's logic was:
R-N-R : lower volume
R-N-F-N-R: keep volume high (or 'reset volume high')
... which, as Pharkas wrote, wouldn't be what you wanted in a campground.
Old 03-07-2019, 07:26 PM   #12
Old Crows
Calypso 2014 View Profile
Old Crows's Avatar
Brilliant Hein! Should be rigged into the back up and blind spot monitors. That would be simple.
Old 03-07-2019, 07:27 PM   #13
OrioN
2008 2500 170" EXT
OrioN's Avatar
Originally Posted by Cheyenne View Post
In the UK it is illegal to sound a horn or warning device between the hours of 23:30 and 07:00 so the usual way is to have a defeat relay wired from the sidelights so the beeper cannot sound when the side lights are turned on, assuming of course you have the lights turned on as it's likely to be dark during those hours!
Keith.
Are Reversing Horns available for sale on UK Sprinters?
Old Crows (03-07-2019)
Old 03-07-2019, 08:05 PM   #14
Old Crows
Old Crows's Avatar
Ahhh only when you pick the chauffeur-shofar option....
https://images.haarets.co.il/image/f...1018316866.jpg
Old 03-07-2019, 08:11 PM   #15
OrioN
2008 2500 170" EXT
OrioN's Avatar
Oy vey!
Old 03-08-2019, 08:07 AM   #16
sprint2freedom
2008 NCV3 170ext
I thought about wiring an on/off switch when I first got my van.
In the end I just unplugged the beeper.. I don't miss it.
sprint2freedom is offline   Reply With Quote
Old 07-11-2019, 11:23 PM   #17
john thomas
I have 08 sprinter where is the fuse for backup alarm I want to turn it off
john thomas is offline   Reply With Quote
Old 07-12-2019, 12:48 AM   #18
I'm going to hazard the guess that there (effectively) isn't one.
The alarm is probably simply wired in parallel with the backup lights.
And the backup lights are powered by the fuse/relay block, which, in turn, gets its power from its primary 80 amp fuse. (yes: eighty).
Sources of wiring info:
http://www.diysprinter.co.uk/referen...nformation.pdf <-- 2007 service manual
http://www.diysprinter.co.uk/referen...nformation.pdf <-- MB wiring diagrams (sect 8W of above)
http://diysprinter.co.uk/reference/0...inter-2500.pdf <-- 3rd party wiring diagrams
... the backup light circuit is on Figure 26 of the 3rd party set, i didn't chase it down in the MB set
(and page 8w-51-3 through -6 in the MB set (i did chase it))
If you don't mind also losing the backup *lights*, then you could disconnect (or add a switch) the backup *switch* itself. Fig 26, or 8w-51-7 in the MB set.
At that point i'd find the beeper and unplug it.
Mickyfin (07-12-2019)
