Old 07-11-2019, 08:43 PM   #1
IPT
Default Spray (gun) adhesive recommendations?
I'm going to put 1/4" foam down, and then some fabric over that for bed panels. So a large area, like 74x56 or something. Plus the lower wall panels too. I know I can use the 3M hi strength 90 in the can, but that's going to be a lot of cans. I'd love to use the Dap Weldwood Contact Adhesive - Landau Top and Trim HHR Solvent Type Spray - but I can't get it locally and no-one will ship it here (Alaska). At least not from Amazon or Ebay and I suspect it'd cost an arm and a leg even if I could find someone to ship it.
So local options are the spray cans as mentioned, or the original formula at the big box store https://www.lowes.com/pd/DAP-Weldwoo...-fl-oz/3033218. Can this be sprayed though? Seems like it'd be a lot smoother and easier to spray this stuff on. I have a compressor and some cheep guns perfect for the job.
Suggestions and recommendations sought and appreciated.
IPT is offline   Reply With Quote
Old 07-11-2019, 09:43 PM   #2
Default Re: Spray (gun) adhesive recommendations?
You can do a google search, but properly thinned, most contact adhesives will spray fine. I am not sure what solvent to use though.
You can also by large/wide rolls of pressure sensitive adhesive. Basically that peel and stick stuff that you see on many products. Hein sells some I think? You could put that down as well.
IPT (07-12-2019)
Old 07-11-2019, 10:05 PM   #3
GSWatson
2013 144
GSWatson's Avatar
That’s actually a pretty small area. A couple cans of spray 90 should be fine.
GSWatson is online now   Reply With Quote
The Following User Says Thank You to GSWatson For This Useful Post:
IPT (07-12-2019)
Old 07-11-2019, 11:14 PM   #4
wankel7
Do a few test pieces to make sure it all works.
What kind of foam?
Great Stuff is an amazing adhesive. Super 90 seems to melt xps
wankel7 is offline   Reply With Quote
The Following User Says Thank You to wankel7 For This Useful Post:
IPT (07-12-2019)
Old 07-12-2019, 12:16 AM   #5
Shawn182
Agreed...we used to occasionally spray a lot of foam at my work and we ditched the spray system for just 3M 90 cans...so unless you are concerned about waste in throwing away cans, the spray gun will be way more hassle than its worth for what you are doing IMO.
While you never really get the coverage area any spay advertises...one can of 3M 90 actually covers quite a bit.
Shawn182 is online now   Reply With Quote
The Following User Says Thank You to Shawn182 For This Useful Post:
IPT (07-12-2019)
Old 07-12-2019, 12:22 AM   #6
3m Super 77 is better for solvent intolerant foam, different solvents. I would test, many foams are fine with 90.
IPT (07-12-2019)
Old 07-12-2019, 12:39 AM   #7
IPT
Thanks for all the input. The foam is a closed cell cross linked polyolefin foam. I have some of the 3M 90 stuff so I will test it out.
I would be curious though what you could thin the other contact adhesive with if anyone knows. My guess is the spray can will maybe do the wood to foam, and part of the fabric but that's it. It would have to be cheaper to thin the gallon. Not to mention as of now this is all mostly just a trial. I'll likely re-do a lot of it next year once I decide and see how and what the usage of the van actually ends up being.
Old 07-12-2019, 12:44 AM   #8
Methyl ethyl ketone, or xylene would probably work. They are pretty nasty, so do it outdoors, or wear a carbon filer mask.
IPT (07-12-2019)
Old 07-12-2019, 02:03 AM   #9
john61ct
 call 1-888-DAP-TIPS (1-888-327-8477)
john61ct is online now   Reply With Quote
The Following User Says Thank You to john61ct For This Useful Post:
IPT (07-12-2019)
