Old 07-28-2017, 04:50 PM   #11
OffroadHamster
Default Re: Anyone fit 285/70/17s on their 4x4?
I got a lot more than a little rub with 285'/70r17. I got a little rub while turning with no wheel travel and quite a bit at 50% lock and any amount of bump travel. I didnt do any trimming, I simply got a heat gun out and re-shaped the plastics a bit.'
Re-shaped plastics; the bumper edge got heated and rolled in from the bottom about 5 inches up. The wheel well liners got massaged back about 1.25-1.5 inches in the center and progressively less moving inward and outward.
OffroadHamster is offline   Reply With Quote
Old 07-28-2017, 05:46 PM   #12
Kirk
Thats a great idea OffroadHamster, I think I will follow and do some heating and reshaping myself. Thanks for the tip.
Kirk is offline   Reply With Quote
Old 07-28-2017, 05:56 PM   #13
JFloFoto
Sweet rig. Love the color.
Sent from my Pixel using Tapatalk
Old 06-20-2019, 01:26 AM   #14
mcguyver
Originally Posted by Kirk View Post
I went with the 285/70/17 BFG KO2s on Methods. I think it looks pretty good.
Took it out camping and did some mild off roading last weekend. I do get a slight rub, but only at full turn while hitting a bump or dip. Will likely do some very minor trimming.
Kirk. Could you please tell me what lug bolts you used?
2012 316 MWB 4WD
mcguyver is offline   Reply With Quote
Old 06-22-2019, 07:18 AM   #15
The Grand Tour
Banned
We're planning to use the 16.00R20 Michelin ZXL on a Mercedes-Benz 4x4. They're 53" tall and are "G" speed-rated up to 55 mph.
Old 06-22-2019, 09:53 AM   #16
Mickyfin
Mickyfin's Avatar
Not a 4x4 but I have slight rubbing with my 245/75/R16 K2's on full lock either side, slightly rubs on the metal sub-frame.
My van is a 170" WB High Top 2012 Volkswagen Crafter 2.0TDi, which was built in the very same German factory as the Mercedes Sprinter of the same year.
Old 06-29-2019, 07:34 PM   #17
aksotar
Factory or aftermarket wheels ?? Right away the correct offset came to mind....
aksotar is offline   Reply With Quote
Old 06-30-2019, 12:56 AM   #18
julie777
Julie
Method Standard has the proper offset on 17" wheels.
265/70R17 Sprinter engineering approved.
285 is likely to rub with wheels turned. Could be on struts, springs, fenders, etc.
Old 06-30-2019, 08:34 AM   #19
mcguyver
I just today fitted 275/70 x17 no rubbing.
2012 316 MWB 4WD
Old 06-30-2019, 11:45 PM   #20
MotoXPress
285/75-17 on black rhino York’s
They barely touch front and rear inner liner. Will heat gun them, simple.
No touch on struts.
MotoXPress is offline   Reply With Quote
