Old 05-20-2019, 01:15 PM   #81
israndy
2007 LTV Serenity
israndy's Avatar
Default Re: Replacement of front brake pads and rotor
I just took it to the Dodge dealership, been more than a couple of years now, but it seemed like a good deal compared to taking it to Mercedes. It was a major job and likely the last trip to the dealer, but I think it was around $400.
-Randy
2005 3500 T1N based 2007 Leisure Travel Van's Freedom II Serenity
Also a 40' Airstream Sky Deck, a 1999 Jeep Grand Cherokee, new 2000 Honda Hybrid Insight, new 2013 Volvo C70 hardtop convertible
And all electric: New March 2018 Tesla Model 3, a 2012 Mitsubishi i-Miev and two 2007 Vectrix VX-1 motorcycles
israndy is offline   Reply With Quote
Old 05-20-2019, 05:16 PM   #82
zaskarkid
here's a dumb question, after installing new rotors and new pads - all thicker, how does the brake system maintain the necessary gap/spacing so that the breaks are rubbing all the time? and does the rear emergency hand brake need any adjustment after replacing rear rotors/pads?
zaskarkid is offline   Reply With Quote
Old 05-20-2019, 05:48 PM   #83
Aqua Puttana
Poly - Thread Finder
Aqua Puttana's Avatar
Disc brakes are self adjusting. The caliper assembly floats and moves as the pads wear down. The hydraulic pressure pushes the pistons/pads against the rotors. When the pressure is released the pistons/pads move back slightly. They don't need to move much. I believe that the pads retreat from a combination of being bumped by the rotor and possibly some action by the seals.
The parking brake shoes are conventional. The adjuster was probably backed off to remove the rotor/drum assembly. So yes, the parking brakes do need to be properly adjusted after new a brake job which included rotor removal or replacement.
Old 05-20-2019, 09:42 PM   #84
Carminooch615
Carminooch615's Avatar
Would someone kindly post the chart showing the difference between the three different types of brake assemblies the sprinter utilized?
Northern NJ / Benevento Italy
2018 Chevy Cruze hatchback RS. Diesel and 6spd manual.
2006 Dodge Sprinter 2500, 140" - 160,000 miles
1999 Jeep Wrangler - diesel swapped OM617 3" lift, 35" tires, 20mpg
Carminooch615 is offline   Reply With Quote
Old 05-20-2019, 10:01 PM   #85
marklg
Is this what you are looking for?
https://europarts-sd.com/custompages/BrakeChart.pdf
Regards,
Mark
marklg is offline   Reply With Quote
The Following User Says Thank You to marklg For This Useful Post:
Carminooch615 (05-21-2019)
Old 05-21-2019, 01:01 AM   #86
Carminooch615
Regards,
Mark
That is exactly it, thank you very much
Old 05-21-2019, 12:57 PM   #87
israndy
2007 LTV Serenity
israndy's Avatar
Opinions on changing brake fluid, please? Every time I look at recommendations it says every 2 years. Well, my vehicles don't move for two years at a stretch, at least not much. Finally using the Non-op feature from the DMV.
Does that mean the fluid is rusting my lines? I have a couple of electric motorcycles from 2007 that have never been in for service because they just don't need it. Should I have been taking them in for brake fluid swaps? Before the brake job I listed above I never thought about the Sprinter, just got regular oil changes.
-Randy
Old 05-21-2019, 03:01 PM   #88
Aqua Puttana
-Randy
The problem with not renewing is more related to corrosion within the CAB aka ABS module than it is rusting. There are some close tolerance parts inside there. If your brake lines are rusting internally you have big problems.
A typical motorcycle has a less complex braking system. It also may use DOT 3 fluid. DOT 3 fluid is more forgiving than is DOT 4. DOT 4 has better wet boiling ratings vs DOT3, but there is some trade off for serviceability.
Some may not agree, but you seem like a perfect candidate for monitoring your fluid condition.
PTE Tester Calibrated for for DOT 4 Brake fluids
https://www.amazon.com/gp/product/B005HVG4GQ
skwoodwiva (07-03-2019)
Old 05-23-2019, 05:01 PM   #89
zaskarkid
when replacing rotors and pads, is it necessary to bleed the brake system?
Old 05-23-2019, 05:08 PM   #90
Bobnoxious
No, bleeding only necessary if system is contaminated with air and or moisture.
zaskarkid (05-23-2019)
