Old 05-21-2019, 10:10 PM   #1
Napabavarian
Default Solar panel choice, considering these
I haven't contacted the seller, but these could be interesting, they have others I may consider, and I may be able to pick up in person to avoid shipping
https://rover.ebay.com/rover/0/0/0?m...2F382631332179
I wan considering 2 kept inside, I could set them out when I stay in the same place for a few days, for the most part I don't have a huge solar need, but it would allow me to stay put for a while and 600w is far more than I need, thus they wouldn't need to be out all the time
Napabavarian is offline   Reply With Quote
The Following User Says Thank You to Napabavarian For This Useful Post:
SD26 (05-25-2019)
Old 05-21-2019, 10:17 PM   #2
bobmac
Default Re: Solar panel choice, considering these
They look good Napa but you may find putting them out and back is a nuisance. I was going to do that with my Troopie so I could park in the shade and put the panel in the sun. Did that one day and then mounted it permanently above the windscreen. And that gave me good sun shading on the dash.
I would suggest roof mounting. Just my $0.02 worth.
Bob M 2002 MWB 4x4 and 2003 long and talls
bobmac is offline   Reply With Quote
Old 05-21-2019, 10:32 PM   #3
Napabavarian
I may go that way, and a single panel.
I was looking at this charge controller
https://www.amazon.com/Victron-Smart...02194930&psc=1
Old 05-21-2019, 10:54 PM   #4
marklg
I'm doing both, some on the roof and I have the flexible ones in the back that I can set out. They are way lighter and easier to move.
Regards,
Mark
marklg is online now   Reply With Quote
Old 05-21-2019, 11:04 PM   #5
Graphite Dave
Dave Orton
10 amp controller is not enough for 300 watt panel if 10 amps is the output from the MPPT. You need minimum of 15 amps.
9.0 amps x 32.9 volts = 21 amps x 14 volts (approx. charging voltage). The MPPT takes low amperage/high voltage panel output and converts it to high amperage/low voltage. Actual panel max. output probably about 75% of panel rating due to heat and flat install.
The Following User Says Thank You to Graphite Dave For This Useful Post:
SD26 (05-25-2019)
Old 05-21-2019, 11:28 PM   #6
Napabavarian
Thanks, sounds like I may need a bit more to be safe
What is the difference between the blue solar charger and the smart solar charger?
Old 05-22-2019, 02:59 AM   #7
Napabavarian
I plan to stop in there to pick one or two up Thursday or Friday, probably Friday, then I'll head down through Nevada and probably across 50 back to Napa, just incase someone needs some solar
Old 05-23-2019, 04:19 PM   #8
hein
Van Guru
If you have time you could swing through Hood River, OR and we can set you up with a mounting system for your panel. 1512 Osprey Drive, Hood River, OR, 97031. No sales tax here.
Here is the layout we would suggest:
https://www.impact3d.com/144_front_v...ars_2lbars.pdf
All the best,
Hein
DIYvan
2010 MB 3500 RV conversion.
The Following User Says Thank You to hein For This Useful Post:
143paul (05-23-2019)
Old 05-23-2019, 04:54 PM   #9
143paul
143paul's Avatar
All the best,
Hein
DIYvan
This is the exact set-up I used on my system (also with one 300W pannel) - it has worked perfectly.
I run my Dometic fridge, the fan, and electronics and I have never had a problem - it has been about 6 months and 6,000 mi of use.
143paul is offline   Reply With Quote
Old 05-23-2019, 05:08 PM   #10
bcman
bcman's Avatar
The SmartSolar series is the same as the BlueSolar, with the addition of a bluetooth connection. You can reprogram your charge points and monitor your charge status from a smartphone.
I got the BlueSolar 100/30 for my single 320W panel, and a separate bluetooth dongle (they didn't make the SmartSolar yet). I've been very happy with it. The Android app is very easy to navigate.
2003 T1N, 140wb SHC passenger van
bcman is offline   Reply With Quote
