Go Back   Sprinter-Forum > General Forums > Pictures & Videos
Pictures & Videos Sprinter Pictures & Videos
Old 07-30-2019, 11:45 AM   #1
Yaroslav
2015 Sprinter 3500
Yaroslav's Avatar
Default AMAZING !
2014.5 Sprinter 3500 Airstream Interstate Ext
Yaroslav is offline   Reply With Quote
The Following 9 Users Say Thank You to Yaroslav For This Useful Post:
autostaretx (07-31-2019), BrennWagon (07-30-2019), fosterama (08-03-2019), Garandman (07-30-2019), glasseye (07-30-2019), Larms (09-24-2019), radair603 (08-12-2019), Tiny Travels (08-08-2019), VanGoSki (07-31-2019)
Old 07-31-2019, 05:05 AM   #2
Default Re: AMAZING !
I think the first guy (probe on Sprinter floor) was vibration testing the floor/frame ... if there was a bad weld, it would cause a different echo pattern.
The automated outer paint system apparently uses electrically-charged paint (a common practice) ... spray positively-charged paint towards a negatively-charged steel body ... you can see the back of the spray patterns bending in towards the body. Far less wastage ... the paint sprayed ends up on the desired metal.
BrennWagon (08-01-2019)
