Go Back   Sprinter-Forum > Miscellaneous > Comments, Suggestions, & Problems with the Forum
Old 12-21-2019, 06:00 PM   #1
Boathead1012
Default can a thread that didn't post be recovered
Can a thread be recovered and posted without having to type it all out again. Thanks for any help I lost one earlier day. I was titled New to me T1N 2004 3500.
just wanted to check before I re do it.
thanks
Boathead1012 is offline   Reply With Quote
Old 12-21-2019, 06:41 PM   #2
john61ct
Default Re: can a thread that didn't post be recovered
Sometimes Tapatalk will ask "do you want to retrieve the post you were writing?"
Otherwise no.
Using a web-based editor is always fraught with risk, too many moving parts, any one goes bad your work gets dumped into that great big bitbucket in the sky.
Better to compose long screeds in a trusted locally-saved plaintext editor app, ideally an auto-saving one,
then copy and paste into the forum UI only when you're all done.
I like Simplenote, free & FOSS, cross-platform and automatically sync's across all your devices, great fulltext search
Also tagging support so can function as a minimalist note-taking templating knowledge base if you don't require more structure, no hierarchical outlining support for example.
If you want that latter, Workflowy is a great tool, also cross-platform, automatically sync's across all your devices, great fulltext search and tagging support. But not FOSS, and if you use it a lot no longer free.
john61ct is online now   Reply With Quote
Old 12-21-2019, 07:04 PM   #3
Boathead1012
Thanks for the response
Old 12-21-2019, 07:08 PM   #4
OrioN
2008 2500 170" EXT
OrioN's Avatar
If you used a web browser, depending on its settings, you use the 'back' button to reveal previous pages and hopefully the one with your input.
