Old 05-02-2019, 02:02 PM   #21
trc.rhubarb
Default Re: Armrests/covers cheap on fleabay
I was not granted access yesterday.
My next opportunity to attempt access to the garage will be Sunday.
My apologies.
2003 Sprinter 140 SHC Moto/ADV Hauler
Please excuse any offensive or gibberish posts - I'm suffering a TBI and don't always think clearly.
trc.rhubarb is offline   Reply With Quote
The Following User Says Thank You to trc.rhubarb For This Useful Post:
Aqua Puttana (05-06-2019)
Old 05-19-2019, 01:53 AM   #22
stebro27
FYI, I solved my uncomfortable, balky adjust sprinter seat problems by installing the seats from an "xj" type Jaguar for $50. per seat (walking around the pick n pull with the base bolt dimensions from the T1N, they were the only ones that came close.. sob! & I did have to take them out myself..)... 12 way power , leather and sublimely comfortable.I had to bend &/or straighten a base mount point or two and judiciously add a few washers, but fit was pretty easy. Wiring was fairly easy with on line available wiring diagrams for the proper year "XJ":. Hint, they do not use the body control unit, they have their own controller under each seat (one of mine worked..became the drivers seat.. the other is still a non moving, but COMFORTABLE passengers throne)
PS; i also found some in an jag "s" type, but it was to badly damaged to get at their mounts.. but they seem to have the same dimensions...
stebro27 is offline   Reply With Quote
The Following 5 Users Say Thank You to stebro27 For This Useful Post:
alexk243 (05-20-2019), Aqua Puttana (05-19-2019), DesertAdventures (05-20-2019), glasseye (07-21-2019), xeres (10-22-2019)
Old 05-19-2019, 02:08 AM   #23
stebro27
I forgot to note, i also took the JAG inner seat belt receivers off and could directly bolt on the merc ones. Electrically .. as I remember, I really only had to find the Hot and ground leads..(Yes, I cut and took as much of the JAG seat wiring..I cut below the carpet.. as I could) I ran wires under the seat and spliced in a 30 amp fuse holder before connecting to one of the large Hot leads to the seat fuse/relay panel.
The Following 2 Users Say Thank You to stebro27 For This Useful Post:
alexk243 (05-20-2019), autostaretx (05-19-2019)
Old 05-19-2019, 04:57 AM   #24
Perce
Sounds great, can you post a few pics please. Perce
Perce is offline   Reply With Quote
Old 06-15-2019, 03:03 PM   #25
Garandman
Garandman's Avatar
Just ordered a pair for $71. Item #293008385197. One of my covers is worn. Had to fix the passenger side so I swappedthe covers.
It appears the three hole versions sell for around $70 while the two hole versions sell for $45 or so.
If you already have armrests and just want to replace the grody covers, you could probably buy the cheaper ones and just use the tops: didn’t find them for sale by themselves.
They come in black. Has anyone used paint to match the originsl blue color?
2006 Sprinter 118” ~ 16” Rial Transporter rims ~ 235/65x16
Old 07-18-2019, 09:31 PM   #26
Garandman
Garandman's Avatar
Mine came in and look good, other than being all black.
Is there a paint code for the medium blue interior color in the 2006 (and likely other years)? If I can't paint them I'll probably order a second set and put all black on both chairs, both arms.
Old 07-19-2019, 02:15 PM   #27
Aqua Puttana
Poly - Thread Finder
Aqua Puttana's Avatar
Possibly a 20 buck Gel pad solution. ($10 ea.)
Depending upon the the condition of your arm rests, this pad stuck to the top may provide enough cover to improve looks and service life. The 2" x 9 1/2" will pretty much cover the OEM arm rest.
https://www.amazon.com/Gelepad-2x9-I.../dp/B01093Q9BQ
Garandman (07-19-2019), jcmadeintheshade@gmail.com (07-19-2019)
Old 07-19-2019, 05:08 PM   #28
A gel pad glued to the hard plastic driver side armrest has worked great for years and is so appreciated every time I drive anywhere. $10 a side is hard to beat.
I recall someone here had found some padded armrests for VW vans also worked and cosmetically looked better.
jcmadeintheshade@gmail.com is offline   Reply With Quote
The Following User Says Thank You to jcmadeintheshade@gmail.com For This Useful Post:
Aqua Puttana (07-19-2019)
Old 07-20-2019, 01:31 AM   #29
Aqua Puttana
I did a search using VW Crafter. These came up.
https://www.amazon.com/gp/customer-r.../RUDYN2TTILACD
This was one review comment.
"Perfect Fit for Winnebago View Mercedes Sprinter Arm Rests"
Probably an NCV3 comment, but should work for our T1N's.
I've added a set to my Amazon cart.
Added:
Ordered a set. I'll update here soon.
Old 08-08-2019, 08:34 PM   #30
Lojack72
Independent
Lojack72's Avatar
Both the armrest cover and gel pads work well on my '02 T1N:
[IMG][/IMG]
Lojack72 is offline   Reply With Quote
