Old 06-19-2018, 02:19 PM   #61
PATECO
PATECO's Avatar
Default Re: LED Headlight Bulbs???
Here is a pic with both new bulbs installed.
2004 Freightliner 2500HC Short/Short Cargo
PATECO is offline   Reply With Quote
Old 06-19-2018, 02:55 PM   #62
Patrick of M
2005 T1N 2500 (NA spec)
Originally Posted by PATECO View Post
Here are pictures of the steps to install them. These bulbs were nice in having a removable collar so that they went into the bulb holders quite easily.
  1. Unplug and remove the old bulb.
  2. Remove collar from the new bulb.
  3. Insert locking collar into bulb holder and re-attach retaining clip.
  4. Insert new LED bulb into locking collar.
  5. Plug in and test.
That removable collar is a great idea. Mine didnít not have that and I had to remove the spring clip and then reinstall it after bulb was in, very fiddle, doable but fiddle.
Patrick of Montreal
2005 T1N (NA spec).
Patrick of M is online now   Reply With Quote
PATECO (06-19-2018)
Old 06-19-2018, 08:30 PM   #63
hkpierce
'02 140 Hi BlueBlk Pass
The pictures show a 110v plug. Do they provide an adapter for the H7 plug?
Old 06-19-2018, 08:39 PM   #64
One call a/c
One call a/c's Avatar
They use standard plug that just plugs right into the stock harness
2006 Long n Tall Cargo.
One call a/c is offline   Reply With Quote
Old 06-19-2018, 08:58 PM   #65
PATECO
PATECO's Avatar
It is not a 110v plug but replicates the back of an H7 bulb
Old 06-21-2018, 05:17 PM   #66
PATECO
PATECO's Avatar
Just a heads up.
When I installed the first bulb, I was not super impressed with the light pattern and brightness. You can see in the picture below, that I had the bulb installed with the heat sink horizontal. After installing the second one, I realized that this put the LEDs facing up and down instead of side to side. I rotated both bulbs, and now the light pattern is excellent, and they provide much more light. In the pictures below, you can see how horizontal the pattern is, and how it lights the road, and not the overhead trees. When I was standing in front of it, it caused a lot of flare in the camera lens, but was not blinding to my eyes
The Following 2 Users Say Thank You to PATECO For This Useful Post:
autostaretx (06-21-2018), socalmbcruiser (01-21-2019)
