Old 07-28-2018, 03:52 PM   #11
Ski Trip
Default Re: Sliding Door step trim install
actually that is the wrong part all together so he was confused.
there is, however, the same part you bought, for the sliding door on the *drivers* side, believe it or not...which does not fit my van, of course. that part he was right about
2017 144" WB Low Roof 4x4 ("Van Haley")
Ski Trip is offline   Reply With Quote
Old 07-28-2018, 09:46 PM   #12
Munmile
I added a Beckson 310 opening port as a ventilation source to the wall of my left slider door step, so I'm going to skip the trim on that side.
cheers,
Munmile
Munmile is offline   Reply With Quote
Old 07-31-2018, 07:19 PM   #13
Farfrumwork
I received my trim piece - PN - 906-686-17-10-7J69
Positions: Right
Description:
Wood floor, side door enterance, with lamp.
I though that this PN was 'with lamp' option as noted, but it looks identical to the piece Munmile has (PN - 906-686-10-10-7J69)
I could cut out the blank section where the light mounts, but I really wanted a part that I didn't have to trim...
I'll inspect the lamp housing and decide what to do. (This item came in just about the biggest box I've ever seen )
Farfrumwork is offline   Reply With Quote
The Following User Says Thank You to Farfrumwork For This Useful Post:
shouldbeasy (08-01-2018)
Old 09-11-2018, 09:29 PM   #14
Farfrumwork
^^ So I finally got around to installing the trim.
The full door trim piece has a embossed line around the back side that matches my original shorty trim piece where the light mounts. I used a dremel to cut out the section and then the light just snaps into place. Added some sound damping in and around and bolted it in. Nice!
I will add some screws to the top edge to keep it from moving around, and possibly deforming/breaking, with kids feet in and out of the slider. I double side taped the lower portion, but the top edge is pretty free to move with a judo kick.
