Old 08-12-2018, 07:13 PM   #1
elemental
Default DPF differential pressure sensor issue - any expert thoughts?
Can anyone with experience diagnosing DPF and differential pressure sensor behavior interpret the
XENTRY regeneration history I was given at a recent visit to MB?
I'm seeking understanding of what the MB diagnosis and XENTRY report means for long-term monitoring of my DPF system. I have made two service visits to MB (total), several months and several thousand miles apart, each one due to a Check Engine light with a diagnosis related to the differential pressure sensor. The vehicle is a 2017 Sprinter 2500 170 with the 3.0 V6.
I was chided by the service advisor for too many short trips that were preventing the DPF from regenerating. He did not seem willing to believe me when I told him I made practically no short trips. I make a couple of 6 to 8 mile trips per week (30 miles per hour), along with 4 to 6 30 miles trips each week (50 to 60 MPH), with the rest of my driving several hundred to a thousand miles at a time (stopping only for fuel).
1. For example, every single entry says that the cause of the termination of regeneration was "IGNITION OFF [0]"; that seems unlikely.
2. Starting with entry #17, a series of regeneration attempts each lasting 0 seconds is noted; I think this is where the tech advisor might have been focused when he suggested that I was making too many short trips. However, each regeneration attempt is 0 seconds, not a random number of seconds that I would expect if it was just getting up to temperature and starting regeneration before I killed the ignition.
3. Finally, should I read the history from top to bottom (i.e., oldest entry is #1, or are the newest entries on the top)?
4. Any other thoughts?
On 2/12/2018 At 400 miles on the odometer, the check engine light came on. Took vehicle to MB workshop for service on 2/13/2018 at 666 miles on the odometer, with the following results:
CLIENT STATES THE 'CHECK ENGINE' MALFUNCTION WARNING
IS DISPLAYED IN THE INSTRUMENT CLUSTER
Cause: ISSUE CURRENTLY UNDER INVESTIGATION BY MBUSA FOUND CHECK ENGINE LIGHT ON AT TIME OF SERVICE, CONNECTED BATTERY MAINTAINER AND SDS, RAN QUICK TEST, FOUND STORED CDI FAULT P170400, PLAUSIBILITY ERROR DUE TO DEFECTIVE EXHAUST GAS PRESSURE LINES BETWEEN THE DIESEL PARTICULATE FILTER ANDTHE DIFFERENTIAL PRESSURE SENSOR. CHECK XENTRY TIPS, FOUND DECEMBER 2017 TECH TOPIC GP 07.04 CONCERNING THIS ISSUE.PER TOPIC INSTRUCTION PERFORMED GUIDED TEST SEQUENCE.PROCESSED FAULT IN XENTRY, PERFORMED COLLATION OF DIAGNOSIS PERFORMANCE DATA, CHECKED DPF DIFFERENTIAL PRESSURE SENSOR(GT CDI), TEST OK. PERFORMED COMPRESSION TEST (GT CDI 2),TEST OK. CHECKED CHARGE AIR SYSTEM FOR LEAK TIGHTNESS (GTCDI 3), TEST OK. CHECKED EXAUST TAILPIPE FOR CARBON FOULING,FOUND TAILPIPE FREE OF CARBON DEPOSITS. CHECKED EXHAUST SYSTEM FOR LEAKS VIA VISUAL INSPECTION, FOUND EXHAUST SYSTEM LEAK TIGHT. PERFORMED PLAUSIBILITY CHECK OF TEMPERATURE SENSORS VIA XENTRY GUIDED TEST (GT CDI 4), TEST OK.INITIALIZED REGENERATION OF THE DPF (GT CDI 5). PERFORMED POST REPAIR COLLATION OF DIAGNOSIS PERFORMANCE DATA WITH ENGINE AT IDLE (GT CDI 6).
Correction: CLEARED FAULT CODE, RETURNED VEHICLE TO CUSTOMER VIA TECHTOPIC INSTRUCTION.
The check engine light stayed off after this service visit until 4,607 on the odometer, when it came on immediately following a fuel stop near the beginning of a 2,600 mile trip. I took the vehicle to MB workshop (different than first workshop) for service on 8/1/1028 with 6,972 on the odometer, with the following results (Note: the mileage in/out is from the visit on 8/10/2018 when the sensor was replaced, not the visit on 8/1/2018 when the need to replace the sensor was diagnosed by MB workshop):
CUSTOMER STATES CHECK ENGINE LIGHT ON
FAILED DIFFERENTIAL PRESSURE SENSOR
CONFIRMED CEL, SCANNED FOR FAULTS. 1 FAULT STORED P18F100
MEASURED VALUES OF DPF ARE IMPLAUSIBLE. PROCESSED FAULT,
CHECKED FOR LEAKS FOUND NONE. CHECKED CONNECTOR TO SENSOR.
CONNECTOR WAS TIGHT AND PINS OK. RECOMMEND NEW SENSOR.
8-10-18 REPLACED SENSOR. RAN INITIALIZATION WITH SDS. TEST
DROVE AND CLEARED CODES. FUNCTIONS NORMAL AT THIS TIME.
MILEAGE IN 7072 MILEAGE OUT 7074.
Attached is the XENTRY report of the “History of regeneration of diesel particulate filter” (this report was printed at my return trip to have the new sensor installed as part of the second service visit):
2017 Sprinter 2500 170 Crew OM642 5-speed auto
elemental is offline   Reply With Quote
