Old 03-14-2019, 11:12 PM   #1
auburnbuilder
Default Redarc Brake Control
I recently installed a Redarc Pro Elite brake control on my van.
(https://redarcelectronics.com/produc...ake_controller)
Installation was very easy, plug and play other than drilling a small hole in dash and running a cat 6 wire from seat base to knob dash location.
The portion of brake control mounted to dash is very small. The brains of the unit I mounted under the drivers seat, I connected the two together with a 8' piece of cat 6 wire.
All you need between dash knob and brains of unit is the cat 6 wire, cat 5 would work as well.
You also need: 1- Tekonsha 3063 harness
1- Redarc TPH-017 harness
8'- cat 5 or 6 cable
Plug the Tekonsha harness into your green connector under seat.
Plug the Redarc harness into the Tekonsha harness.
Plug the other end of Redarc harness into Redarc brake control.
Brake control works very well, and is much more easily located than other brake controls.
auburnbuilder is offline   Reply With Quote
Old 03-14-2019, 11:16 PM   #2
auburnbuilder
Default Re: Redarc Brake Control
Almost forgot, I did get a switch insert from Redarc that says "brake control".
Others are available but not needed for install.
https://redarcelectronics.com/collec...switch-inserts
Old 03-14-2019, 11:19 PM   #3
auburnbuilder
Do NOT get a 3030P harness from Tekonsha, it is not wired correctly for our vans.
The 3063 is the correct harness.
(I called Tekonsha and confirmed this.)
