Go Back   Sprinter-Forum > General Forums > Off Topic
Off Topic Nonrelated Sprinter things to say? This is the place to be (although certain threads that are politically or religiously charged will be moved to the DZ).
SubForums: Health The Funnies The Danger Zone
Old 06-25-2019, 01:14 AM   #1
The Grand Tour
Banned
Default The first passenger car to pull a wheelie on launch during a drag test?
What do YOU think was the first stock passenger car to pull a wheelie on launch during independent and published acceleration testing from a standing start? The Dodge Challenger SRT Demon, or the Porsche 911 Turbo S?
Old 06-25-2019, 05:58 PM   #2
Default Re: The first passenger car to pull a wheelie on launch during a drag test?
Porsches were (probably) too "refined" to engage in such antics.
But they did have the "endearing" habit during servicing that: IF you removed the "bird cage" air filters above the carburetors to balance them, a lovely blue flame-front would appear hovering above the throat thanks to the very early opening intake valves (which also overlapped with the exhaust valves still being open).
The bird cages were a combination filter and caged "miner's lamp" flame arrestor.
--dick (ah, the good old days (the above is a tale from 1970ish))
Old 06-25-2019, 06:16 PM   #3
The Grand Tour
Banned
Is that your guess?
Just about all modern engines have intake/exhaust overlap.
And engines with IR (Individual Runner) intake manifolds, are subject to fuel "stand off", due to the sound waves bouncing back and forth from the intake valve to the intake trumpet. More so with carbureted engines. Under certain conditions, you can see a "fog" of fuel hovering above each barrel.
But any flame coming out of the intake tract would be a backfire, and that's not a normal part of any internal-combustion engine's operation.
"Tea strainer" screens are used for two purposes, in two different applications. The first application is a race car with no air filters- the tea strainers are used to prevent rocks from getting into the engine and causing catastrophic engine failures. The second application is in road vehicles with filtered IR intakes- the tea strainers are used to prevent backfire malfunctions from setting the air filter element on fire, which could burn the car down.
Old 06-30-2019, 06:46 PM   #4
The Grand Tour
Banned
I will now give the answer:
The Porsche 911 Turbo S was the first.
I've never actually seen a stock Demon pull a wheelie at all.
Old 06-30-2019, 11:56 PM   #5
The Grand Tour
Banned
When Motor Trend tested the 911 Turbo S and it pulled a wheelie, the article was titled "The 2017 Porsche 911 Turbo S is Motor Trend’s Hardest-Launching Car Ever Tested" and below that it said "The New 911 Turbo S Launches Harder Than the LaFerrari, GT-R, and Model S P90D"
https://www.motortrend.com/news/2017...r-ever-tested/
The Demon? ...not so much...
