Old 07-23-2009, 12:02 AM   #1
maxextz
Rollin Rollin Rollin.....
maxextz's Avatar
Default door adjustment
door adjustment in pdf format.
max..........
The Following 19 Users Say Thank You to maxextz For This Useful Post:
Andy in NH (06-29-2011), Ant_van (03-26-2011), autostaretx (10-22-2010), baldeagle (12-11-2009), brutimus (01-20-2016), CJPJ (10-22-2010), Clark2 (05-17-2011), dronsin (03-12-2010), flman (10-20-2010), gersad (07-19-2011), Hellosprinter (05-28-2017), kieron308 (11-06-2018), krisinak (02-25-2017), long1pham (12-18-2014), mendonsy (07-26-2009), Rocketgurl (10-17-2018), sp99drac9r (10-09-2009), Toddius (12-22-2015), utino (09-21-2014)
Old 09-14-2009, 03:02 PM   #2
sail-do
jag
Thumbs up Re: door adjustment tech doc - Thank you
Thank you for this document
sail-do is offline   Reply With Quote
The Following User Says Thank You to sail-do For This Useful Post:
Alex (09-14-2009)
Old 09-16-2009, 01:08 AM   #3
teamtexas
A Dad owner with a '03
teamtexas's Avatar
Default Re: door adjustment
Thanks for that link Max, it will come in handy for future adjustments.
Dan
Old 10-09-2009, 05:01 AM   #4
sp99drac9r
sp99drac9r's Avatar
This post is perfectly timed, thank you. I just got my 2006 140" SHC and the rear doors are in dire need of adjustment.
Question: where did this document come from?? It looks like it might be from a factory shop manual that I am desperately looking for.
sp99drac9r is offline   Reply With Quote
Old 10-09-2009, 04:22 PM   #5
glasseye
glasseye's Avatar
Let us know how you make out. I'm finding that, no matter what adjustments I do, they're still loose at the top. Squeek, squeek, rattle, rattle, curse, curse.
glasseye is online now   Reply With Quote
Old 12-03-2009, 07:53 PM   #6
sp99drac9r
sp99drac9r's Avatar
So I took a first pass at adjusting the rear doors. Previously, the skid plate on left rear door would bind badly at the bottom. Now it closes okay, but still without the smooth operation I'd like to see from a Mercedes product. I'm pretty sure this could improve. I'll take a second pass when I strip out the van to insulate it, so we'll see if I can improve upon that.
Project Mo'ab
Mobile Habitation
"La Paloma" Prototype
2006 SHC 2.7L turbodiesel
Old 10-21-2010, 12:07 AM   #7
flman
In Transit
Thanks Max, we are having door problems on our T1N, we will use it when we get a chance
Old 10-21-2010, 11:52 PM   #8
2002sprinterman
Minnesota
2002sprinterman's Avatar
Thank you for posting this info. You don't also happen to have the procedure for the front doors do you?
Kevin
2002 Sprinter 2500HC 140" wb short top and only 281,000 miles on the turbo diesel!
2002sprinterman is offline   Reply With Quote
Old 10-22-2010, 02:07 AM   #9
procedure for the front doors?
It's in the service manual, and it's pretty simple: adjust hinges to get the round-the-door gap "even", then adjust the striker bolt.
The 2003 service manual can be downloaded from:
http://204.95.8.185/sprinter/sprinter-manual.pdf
and/or
http://www.filefront.com/thankyou.ph...4f9a69c436fa8e
good luck
2002sprinterman (10-22-2010)
Old 10-22-2010, 02:38 PM   #10
2002sprinterman
Minnesota
Dick,
Thanks for the links. The first one was inactive and the second went to the manual for a 2005. Apparently there was a design change in the hinges on the front doors from 2002 to 2005. The hinges on my Sprinter takes a torx socket to adjust the way it looks....in addition to the torx headed bolts. I just bought my Sprinter and want to make sure everything is in correct alignment before I spend the big money to wrap it in advertising for the business.
Thanks to all for the helpful posts here! You are a great group of people and I hope to get knowledgable enough about my Sprinter to actually help someone else someday!
Kevin
