Old 05-04-2018, 06:04 PM   #191
kite
Default Re: Nag1 TECH ALERT
Unless I am missing a thick coating of brown clutch material? Is such a buildup present?
No sludgy coating on the filter. The fluid definitely had a brown tinge but hadn't clogged the filter so I don't think it's what you were referring to. (see photos).
Originally Posted by Flatheadfever View Post
What about a shift improver kit. I see them listed on rock auto.
Just learned about it yesterday, and am considering it! I'll report back if I do it, and if things improve.
kite is offline   Reply With Quote
Old 11-15-2018, 01:54 AM   #192
rustdogbrown
Did you do the shift improvement kit? Has anyone done the shift improvement kit?
rustdogbrown is offline   Reply With Quote
Old 11-15-2018, 02:13 AM   #193
A friend did the kit, and reports it improved his van (200k+ miles) performance substantially. Mostly related to poor TC clutch take up.
Old 01-12-2019, 05:47 PM   #194
Spendlove57
The electrical board can now be unclipped(2 push clips) and separated from the valve body.
I have everything apart right now and I can not figure out where these "push clips" are to get the board off. Can someone please help before the walmart security throws me out of this parking lot pleaase! haha thanks.
Spendlove57 is offline   Reply With Quote
Old 01-12-2019, 07:53 PM   #195
Dougflas
DAD OWNER
See if this helps. If I remember, the conductor plate just pops off as it is held by plastic pieces built onto the plate
2005 TIN Sprinter 2500
Located in Beverly Hills, Fl.
Old 01-14-2019, 03:59 PM   #196
SprinterSnale
NorCalSprinterCampout
SprinterSnale's Avatar
Replaced the conductor plate 2500 miles ago on the 05 T1N at 188,000. The transmission has shifted great ever since. Holds in low gears up grades longer before up-shifting and automatically downshifts earlier relative to engine load. (though I still manually downshift to 4th often). It seems to have adapted better to my driving style and the rumble strip noise (RSN) also improved.
I never conducted the conductor plate autopsy, but the visual inspection showed iron filing build up and browned leads that I suspect were losing resistance and/or solid contact where the solenoids poke into the leads.
SprinterSnale is offline   Reply With Quote
Old 06-09-2019, 03:44 PM   #197
TROLL
2007 Winnebago View 23H
I was performing this service to try and correct some issues I've been having and during disassembly I cracked one of the plastic solenoid covers on the valve body. Does anyone know where I can find a replacement? More info and photos here: https://sprinter-source.com/forum/sh...61&postcount=1
TROLL is offline   Reply With Quote
Old 06-13-2019, 12:45 AM   #198
A couple updates.
#1
The thread that Troll [Not "The Troll"] directed to ultimately revealed that the cracked plastic covers in question were deleted on newer OEM replacement parts. The covers are not needed.
#2
There is a DIY method to check that the transmission solenoids are functioning over and above just checking the coil ohms.
Thanks goes to BenJohnson, and of course the Youtube video guy.
Transmission Valve Body - "pressure" test those solenoids!
https://sprinter-source.com/forum/sh...ad.php?t=76805
Midwestdrifter (06-13-2019)
