Old 02-15-2018, 12:59 AM   #181
kite
Default Re: Nag1 TECH ALERT
I have some somewhat annoying transmission behavior on my 2004 van, though I'm not sure how abnormal it actually is. Curious to hear from others if they notice this, and if the speed sensor cleaning (or other maintenance) may improve it.
behavior 1.
During normal acceleration from a stop, upshifts have the feeling of slipping (especially to 2nd and 3rd gears). Let's say the shift starts from 2300rpm, RPMs will drop to around 2000rpm, and stay there while speed increases, then rise again once engine speed and transmission speed match. If I step harder on the accelerator during this "not fully engaged time," engine speed drops below 2000 quite quickly, fully engaging the higher gear.
My first thought (or hope) is that this is the torque converter clutch engaging, and is working as intended. But these transmissions remain a bit of a mystery to me.
behavior 2
When coasting, RPMs drop some expected. When I press on the accelerator, RPMs overshoot, then settle into gear. This gives the feeling of delayed response, and also just makes me worried my transmission has issues.
For instance, I can be coasting at 22mph @ 1200 rpm. When I press the accelerator, RPMs briefly reach 18-1900, then drop into gear at 1500rpm.
Here's a video that hopefully shows it: https://photos.app.goo.gl/w1fAIUC6Y63aJLnP2
Thanks for any insight you might have!
kite is offline   Reply With Quote
The Following User Says Thank You to kite For This Useful Post:
VinceP (04-30-2018)
Old 04-23-2018, 09:29 PM   #182
SprinterSnale
NorCalSprinterCampout
SprinterSnale's Avatar
My turn with a naughty NAG1. 05 T1N 3500 183K
I've had sporadic soft limps for awhile sticking in 3 or 4 progressing in frequency. I cleaned grounds contacts and strap, checked light bulbs, relay and TCU looks clean. After clearing codes, the 'Speed Senor 3' malfunction reappears. Dr.A has been in touch and said check wiring to sensors first. I will measure resistance, can't scope it. The wiring 'looks' good (not fried by exhaust).
I have one wicking question that I can't find addressed in this thread.
--Does wicking occur on the outside of the wires (on insulation exterior) or is it possible the capillary action occurs inside the insulation along the copper strands? --
The reason I ask is there is a section of wire loom just before turning upward toward the driver seat that appeared to be oily...but nowhere else along the loom run. I imagine it could have been oil from the road or slop from above at some point. But not sure.
The tranny and TC fluid, filter and replacement connector service was performed 30k back, but I'm going to use new fluid and insert a new conductor plate to hopefully disappear from this thread.
I talked with my local ambulance fleet mechanic who said he has done a few conductor plate refits, but hasn't had to perform this on any NCV3's newer than 2010. He didn't want to do mine, but instilled confidence I could do it ("Yeah, I host a Sprinter Campout" haha).
Take a look on YouTube, and it is obvious this is a persistent problem on many '00 era 5-speed Mercedes transmissions that many have successfully solved, often with Chinese conductor plates (no thank you).
My booty from EPSD just over $300 to the door...
Time to sterilize the work bench and check the weather. Don't want to do it on a windy day.
SprinterSnale is offline   Reply With Quote
Old 04-24-2018, 10:49 PM   #183
Originally Posted by SprinterSnale View Post
... or is it possible the capillary action occurs inside the insulation along the copper strands? ...
In my mind that is exactly how it happens. The insulating sleeve is a sealed tubing with the ATF wicking along the copper strands.
If you have ATF in the area of the TCM plug it has been reported that carburetor cleaner works to clean things up.
SprinterSnale (04-25-2018)
Old 04-30-2018, 01:10 AM   #184
VinceP
2005 158" High Roof Pass.
Kite,
Funny enough, I was driving my '05 today, and i was wondering if I had a normal behaviour, doing the EXACT same thing. Feeling kind of "Slipping@ between 2nd and 3rd. But I cannot feel any "real" slipping as if i press the accelerator, the car goes in gear and no slippage. It really reminds me of a TC lockup engaging. Kinda weird. My tranny has been rebuilded at 225K Kms, 3 years ago. I am due for a Tranny service, so I'll see how it behaves after that.
Rusty but Happy Sprinter in Montréal
VinceP is offline   Reply With Quote
Old 04-30-2018, 05:02 PM   #185
SprinterSnale
I did not replace the conductor plate yet, because I pulled the electrical connector out of the tranny and discovered 20 drops of oil wetness within. (I did not want to pull it that until a new seal was on hand). This connector seal has 29K on it. Sprayed contact cleaner in loom side connector then dried with compressed air and carefully wicked out the oil of the tranny side. Loom wires all measured typical resistances.
Put it back together, cleared codes, and 'sensor 3 data' appears to be functioning correctly and feels smooth the first 50 miles of local driving. Longer driving will shed light, but with all the thread warnings about replacing the conductor plate only if absolutely necessary, it will be interesting to see if this bit of oil was causing my blues. It seems plausible.
Old 04-30-2018, 06:01 PM   #186
kite
Originally Posted by VinceP View Post
Kite,
VinceP - thanks for the reply. It's not a great feeling, right? Did it just start happening?
I'm still curious if others are just used to this behavior or if it's abnormal.
Since I posted, I performed a tranny service, and cleaned the speed sensors. Symptom 2 from my first post did improve (not 100% fixed). Symptom 1 (what you're feeling) didn't change noticeably.
I found what I think is some friction material and metal chips on the filter. From what I've seen in other posts the metal might be acceptable. The bits that might be clutch don't give me much hope. Anyone have thoughts?
photo attached
Old 05-03-2018, 08:19 AM   #187
Looks like a typical filter contents.
I have done some reading, and nag1 trans use a multi-port plunger to regulate flow in the main oil circuit. This can wear resulting in non optimal tc clutch behavior and or lag. User jackbombay installed an aftermarket kit (new plunger) which he reports improved his trans behavior, and solved a persistent smoke on take off issue. It might be worth searching for his thread.
My van also has a delay/lag in 2/3 where the tc clutch is slow to switch from coast to accel slip ratio.
Old 05-03-2018, 11:22 PM   #188
kite
midwestdrifter - Thanks for the tip about the regulator valve spring thread. Interesting indeed - I wish I'd known before I had the valve body out! It would have been a no-brainer to try it.
I think you mean this is not normal. Please confirm.
Does this mean you get a little flare when you step on the gas after coasting?
Old 05-03-2018, 11:33 PM   #189
Your filter contents appear normal. Not concerning. Unless I am missing a thick coating of brown clutch material? Is such a buildup present?
I do get a bit of an rpm rise under some circumstances. It takes half a second for the tc clutch control circuit to ramp up pressure I think.
Old 05-04-2018, 09:30 AM   #190
Flatheadfever
What about a shift improver kit. I see them listed on rock auto.
Kind regards,
Lindsay
I say "I'm retired" my wife says " im just unemployed"
2006 118" low roof general cargo/camper van
EastCoast lifestyle
Flatheadfever is offline   Reply With Quote
