Go Back   Sprinter-Forum > General Forums > Pictures & Videos
Pictures & Videos Sprinter Pictures & Videos
Old 11-06-2018, 12:37 AM   #1
turkeypie
Default 3D Printed - Rear door badge - emblem
Made this up today with my 3D printer
turkeypie is offline   Reply With Quote
The Following User Says Thank You to turkeypie For This Useful Post:
IPT (01-20-2019)
Old 11-07-2018, 10:57 AM   #2
lockrob
Default Re: 3D Printed - Rear door badge - emblem
I want one ! Pm
2007 300k
Keeping Miami locked for 30 years
lockrob is offline   Reply With Quote
Old 05-03-2019, 05:33 PM   #3
turkeypie
Hing glider badge by request.
Old 05-03-2019, 06:40 PM   #4
turkeypie
Safe & Lock Badge
Old 05-03-2019, 06:42 PM   #5
OrioN
2008 2500 170" EXT
OrioN's Avatar
What is the basis or type of plastic being used?
Can the plastic be 'coated' or finished, and with what?
Old 05-04-2019, 02:54 PM   #6
turkeypie
3D printer filaments can vary in type and characteristics. Currently using PETG.
Old 05-04-2019, 10:41 PM   #7
Leonid
Those 3D printings for the rear door badge look great!
Leonid is offline   Reply With Quote
Old 05-05-2019, 12:00 AM   #8
Garandman
Garandman's Avatar
Most hobby printers use PLA, which doesn’t hold up very well in an automotive environment.
Some better hobby printers can process PETG, which has substantially better physical properties, particularly UV resistance, although it doesn’t paint or solvent bond well. Temperature resistance is much better than PLA: 70-80° C which is sufficient for many aftermarket automotive applications.
ABS can be painted or even plated, one of the reasons it is widely used for automotive parts and office equipment. Typically the part is post-processed first for a smoother finish by solvent honing, sanding or both. You can also solvent bond it, ultrasonically weld it, machine, drill, or insert metal inserts. Most hobby printers do not have the process control to run it, and it is considered finicky and exotic, while it is actually one of the lowest performance thermoplastics in the commercial 3D printing world. Temperature resistance is around 100° C so it can stand up in a hot wet environment.
We have a Stratasys printer that uses ABS. If you want something printed I’d need an STL file, the neutral file format widely used in 3D printing.
2006 Sprinter 118” ~ 16” Rial Transporter rims ~ 235/65x16
The Following 2 Users Say Thank You to Garandman For This Useful Post:
OrioN (05-06-2019), Tiny Travels (08-08-2019)
Old 05-05-2019, 01:19 PM   #9
Bobnoxious
I want on that says TOYOTA.
QuadAngler (09-13-2019)
Old 05-05-2019, 03:33 PM   #10
turkeypie
My designs are not open source, you can always make you own .stl files but you don't have my consent to reproduce mine. Notice that mine are PETG and printed on a TAZ 6, they paint up just fine.
