Go Back   Sprinter-Forum > Sprinter-Based RV's & Conversions > Sprinter-Based RV Brands > Airstream > Interstate
Old 02-01-2020, 08:12 PM   #1
justinshort
Default 2020 Interstate Poynting Pre-Wire
The pre-wire bundle for the Poynting Antenna that's found in the rear cabinet has a female power adapter plug in it.. does anyone know what this is intended to power? My best guess is that it's for the router that's used with the Airstream Connect service. If so.. does that mean it's for the PepWave Max Mini that Airstream uses?
justinshort is offline   Reply With Quote
Old 02-10-2020, 06:18 PM   #2
Calvin Maison
Default Re: 2020 Interstate Poynting Pre-Wire
Hi Justin,
Does this extra cable have an RP-SMA adapter? My bet is that this is an extra cable as the MAX-BR1-MINI only has 1 wifi connector while the Poynting antenna has two cables for wifi. If that is the case, no need to worry about it.
Calvin Maison is offline   Reply With Quote
